      02-24-2018, 09:27 AM   #1
Volball33
Drives: Z4 3.0i
Z4 3.0i wheel/tire fitment?
Checking on fitment w some 19x8.5 et35, 19x9.5 et33 w standard suspension on 3.0i. Also any advice on tire size would be appreciated. Should there be any rub w these? Thanks in advance!!
      03-01-2018, 08:30 AM   #2
StigJ
StigJ's Avatar
Norway
333
Drives: '06 Z4 Coupe & '14 F30
Should be fine. I recommend 225/35 front and 255/30 rear. If tire is a skinny one you can use 265/30.
I use 225/35 on 8,5 ET34 and 265/30 on 10" ET41 with no issues.
Tried 3mm spacers one time at the rears. Tiny rub. 10" ET38 does poke 1mm more than 9,5 ET33.
      03-02-2018, 05:07 PM   #3
proboner
Drives: 2003 Z4 3.0 6-speed
As stated you should be good. I have 19x8.5 +35 and 19x9.5 +35 and ended up running M sized tires (225/40/19 and 255/35/19) and rub a bit on the wheel well plastics up front, but other than that it's perfect.
