      06-06-2017, 01:34 PM   #1
Rombbb
Drives: Z4MC
Happy new Z4MC owner, but rear camber is off
Looks like left rear wheel has more camber than the right.
Car has the KW Variant V2 coilovers set, but can't find anywhere whether they have adjustable camber at the rear. In the pic it's not really clear but it really has quite a lot of camber to the left.
At the right the wheel and fender pretty much line up. At the left the top of wheel is a bit inwards into the fender.
I noticed after purchase that the car had some kind of paint job, so I was immediately worried that it's simply a bent suspension setup or something due to past damage
Would that be possible or do you think it's simply a matter of re-aligning the KW's ?
Thanks !
      06-07-2017, 01:33 PM   #2
The HACK
The HACK's Avatar
1820
Can't tell from the picture. Take it to an alignment shop.
      06-10-2017, 02:55 AM   #3
Rombbb
Drives: Z4MC
Ok thanks, but thing with alignment shops is, besides the price, whether they know all cars. You have to clear quite some upholstery to get to the springs in the back so assuming this is their first Z4, before they go figuring that out for themselves (under time pressure because I'm not their only customer, probably), I'd like to know whether those KW V2's are adjustable at all at the back.
      06-10-2017, 03:01 PM   #4
The HACK
The HACK's Avatar
1820
Why would they need to clear anything to adjust the camber in the rear? The rear cambers are adjusted via 2 eccentric bolts on the lower control arm.
Camber adjustment is independent of whatever aftermarket coil overs you have on. The only question is how much lowered the car is and if the camber is out of the adjustment range due to excessive lowering. My alignment shop was able to get my KW clubsport rear camber to exactly 2.0 degrees, dead balls accurate.
      06-20-2017, 12:46 PM   #5
Rombbb
Drives: Z4MC
Thanks man ! Just the info I needed. Up to the alignment shop it is
      06-22-2017, 08:43 PM   #6
Mirko
Mirko's Avatar
It looks like you have too much toe, the front of the rear tires are pointing inward too much.
