11-21-2017, 02:56 PM | #23 | |
Rep 6,731
Sounds like a pretty rad car, If you decide to try it, please do post some photos!
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
01-05-2018, 01:38 PM | #24 |
Rep 397
Did not get a response on the other Apex thread. Wondering if you gentlemen can answer the below:
http://www.zpost.com/forums/showpost...95&postcount=4 Thanks |
01-05-2018, 02:10 PM | #25 | |
Rep 6,731
We would still recommend the 5mm spacer to clear KW/Ohlins systems up front due to the over "bulkiness" of these kits over stock. The extra 2mm of clearance that you gain with the 19x9.5 ET33 over an ET35 is not sufficient enough to clear the suspension, in most cases. Although this is also affected by tire size and compound, we would recommend a 5mm spacer just to ensure proper clearance without risk of rubbing on the coilover. I hope this helps clear up this confusion! - Max
01-05-2018, 02:25 PM | #26 | |
Rep 397
Since 18x9.5 ET35 front setups are able to clear with 5 mm for KW/Ohlins/Bilstein... Would it make sense that a 3 mm spacer would be sufficient on a 19x9.5 ET33 setup bringing the effective offset to ET30? If the 3 mm spacer would be sufficient it would eliminate the need to possibly get the TMS front hub extenders with the use of a 5 mm spacer? |
05-11-2018, 02:53 PM | #27 |
Rep 6,731
Now available due to popular demand, red APEX centercaps! Use this link to check them out and place a pre-order.
05-24-2018, 04:44 PM | #28 | |
Rep 2,702
FL5 in anthracite. Love the style
05-24-2018, 05:37 PM | #29 |
Rep 6,731
Love the setup! Let's see some more...
06-21-2018, 12:38 PM | #30 |
Rep 6,731
09-06-2018, 04:22 PM | #31 |
Rep 6,731
Now available: Federal 595RS-RR Tires
APEX is proud to now offer Federal 595RS-RR tires with our wheels. This tire is an excellent and much more affordable option for those looking for an aggressive track-focused tire that can still be used on the street.
12-12-2019, 04:12 PM | #32 |
Rep 6,731
Unrivaled functionality. BMW Z4 M Coupe on APEX FL-5 wheels.
