      09-05-2013, 06:08 PM   #23
IN10SS
Drives: 2007 Z4M Roadster
Way to go. Nice work!
      09-09-2013, 11:04 PM   #24
StickMon
StickMon's Avatar
Drives: 2006 MR
It all worked as expected.
See update to my "name that coupling" thread.
Now I have 2 Vanos air adapters!
      11-03-2013, 03:22 PM   #25
Shipkiller
Shipkiller's Avatar
Drives: Me
Originally Posted by StickMon View Post
Vanos mating connector, Tischer, 61138383300, $3.00
Leads with pins for above, qty 6, Tischer, 61130005199, $2.20 each
Bud Box CU-789, DigiKey, 377-1938-ND, $3.70
SPDT switches, On-Off-On, Momentary, qty 2, DigiKey, EG2388-ND, $2.70 each
12' 10 AWG jumper cables, Amazon, $5.96
So, not including tax and shipping, I'm up to $31.26.
Had everything else. You can get everything else at Radio Shack or equivalent for about another 5 bucks.
Question.
When I interrogate P/N: 61130005199 it comes up as Socket Bushing, either left or right..
I am assuming this does not matter and they are talking about the left or right side of the car... and of course they come up for a 2010-2014 BMW 750.
also, do you have the drilling template you used in electronic format?
      11-03-2013, 03:47 PM   #26
StickMon
StickMon's Avatar
Drives: 2006 MR
Here's what I get from ECS.
Those are the ones I used.
Template to scale attached.
box template Model (1).pdf
      11-03-2013, 04:25 PM   #27
Shipkiller
Shipkiller's Avatar
Drives: Me
Thanks..
I have built hundreds of multi-pin connectors but have never had them referred to as left or right pins... of course these are mil-spec connectors.
Sometime this winter, I plan on proactively upgrading the exhaust hub. This is the first step.
      03-11-2020, 04:06 PM   #28
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
Reviving this thread!
I am getting ready to do the VANOS on my Z4M with the Beisan goodies as preventative maintenance along with the VAC exhaust hub. I have rebuilt a few VANOS systems on other engines, and the S54 doesn't seem like a much larger challenge except for the VANOS timing issue due to the clearance on the E85/86 chassis and the need for this switch.
Unfortunately for me, I am COMPLETELY useless when it comes to electrical stuff, and have no confidence that I would be able to build this box. I also don't like being bent over a barrel financially for special tools unnecessarily
Anyone here that built one willing to sell theirs?
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
