      07-24-2011, 08:20 PM   #1
THE JEDI
Drives: 2005 Z4 2.5i
Removing The Oil Pan On A Z4
has anyone evr removed their oil pan on your z4..I busted the oil pin, and now I have to remove the oil pan to get the pin out,,anyone ever done this..help is much appreciated.
      07-24-2011, 08:54 PM   #2
arggg45
No_Country
11
Drives: fairly quickly.
Here you go, see the attached pdf.
"It will not have enough power until I can spin the wheels at the end of a long straight in top gear."
-Mark Donohue
      07-24-2011, 09:18 PM   #3
THE JEDI
Oh dude thanks very very much I was feeling like the village idiot till I read that it broke because it was supposed to if i gave it to much of a turn....thanks bro.
      11-14-2013, 09:40 AM   #4
Mikeinaz
Drives: 2005 Z4 2.5l
Does anyone have directions or illustrated instructions on how to lower the front axle on 2005 Z4?
      05-21-2019, 02:46 AM   #5
abelgonzaleZ4
Drives: 2006 BMW Z4 SilvrConvert 3.0i
Can someone post the attachment again?
It disappeared
      05-21-2019, 11:04 AM   #6
Steeler
Steeler's Avatar
2428
Doesn't really tell you anything you didn't already know.
The big task is supporting the engine from above while you take down the subframe below.
I have a thread on here somewhere. I used a piece of aluminum structural tube and nylon ratchet straps to support the engine when I did my OPG. Mind you I had most of the ancillary parts off my motor at the time.
Here is my thread. Not sure why I am seeing some pics upside down.
https://www.zpost.com/forums/showthread.php?t=1208850
