      02-07-2014, 02:16 PM   #1
rmonte4
Drives: 2007 BMW Z4 3.0si Roadster
Armrest tear - How to mend?
The driver side door armrest recently developed a tear in the vinyl from my elbow rubbing on it over the years.
Is there anything i can do to mend it or stop it from getting worse? Its doubled in size over the past couple months.
2007 Z4 3.0si Roadster
      02-07-2014, 03:32 PM   #2
GP20
Drives: Z4M, F80 M3, 991.2 GTS
http://leatherz.com/Merchant5/mercha...de=Z4_Armrests
      02-07-2014, 08:49 PM   #3
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Above is probably the best option. I went with Fibrenew to fix the vinyl, but it didn't work out tool well. They said that our vinyl is pretty thin. They ended up reinforcing the area with cotton gauze so it will be less likely to tear again. I'll probably get the LeatherZ armrests one of these days.
Here is my before picture:
Here's a pic of the finished product.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      02-08-2014, 09:15 AM   #4
usaz4mcr8cr
usaz4mcr8cr's Avatar
13
Drives: Z4MC
I have a pair of these armrest in black leather for sale. $65 shipped.
      02-09-2014, 01:45 AM   #5
rmonte4
Whoa, Thats perfect!
THANKS
      02-09-2014, 01:47 AM   #6
rmonte4
Yea with the initial research I did I thought what you did would be my best option. But the LeatherZ looks like the perfect solution right now.
      02-09-2014, 08:34 AM   #7
bignosejim
bignosejim's Avatar
The only good thing about my ugly repair is that those cracks won't grow anymore. The LeatherZ armrest should slow it down also. I was told that using your elbows to shift your body weight after getting in the car is what starts those cracks in the first place.
      02-09-2014, 09:15 AM   #8
Steeler
Steeler's Avatar
2428
THANKS
I went the same route to cover up the arm rest split.
Just a suggestion, take a mini grinder or Dremel tool and grind/sand down the high spots where the crack is ,it will help the leatherZ part stick better and sit flatter.
      02-09-2014, 10:52 AM   #9
rmonte4
THANK YOU, nice tip.
