      08-03-2017, 03:47 AM   #1
Caosa
Drives: Z4MC TiAg
Airbag Light and Fault code Help
Hey everyone,
I've had my airbag light on for a while now: I figured it wasn't anything major as nothing major had happened to my car.
I took it in for an Inspection II service and asked the Indy to clear the code. He said it was error code: 93D7.
He tried to reset it but it came straight back. Apparently the ACSM (active crash safety management) module needs replacing. Any validity to this?
I know i've put my knee on the seats once before could I have damaged the sensor? I've also taken my steering wheel off a few times with the battery disconnected so that I could recondition it.
What do you guys think?
Also in the event of a crash would the airbags deploy if this has not been cleared?
      08-14-2017, 10:13 AM   #2
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
I don't doubt that one weighted knee on the passenger seat is all it would take to break the occupancy sensor mat. That said, is that error code for a broken mat?
      08-15-2017, 11:08 PM   #3
Caosa
Drives: Z4MC TiAg
Thanks for replying - nope apparently my indy said it was that the ACSM needed to be replaced?
      08-16-2017, 12:54 PM   #4
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
There are specific codes for the passenger seat occupancy sensor and for the air bags. Each is independently sensed and can be fault isolated by the SRS system.
The fault code is calling out the controller so it's an issue related to it, but it could be a power issue. If power to the controller is lost or intermittent, the fault isolation will potentially cite the controller as bad.
Top Down 365
      08-17-2017, 01:34 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
ACSM Module for sale.
      11-16-2017, 09:56 AM   #6
DJKapeesh
DJKapeesh's Avatar
311
Drives: 11' 135i, 13' 911 C2S, 10' X5D
Same problem for me, would like to know your solution
Current: 13' C2S 911 / 11' 135i / 05' Xrunner/ 10' X5D (Youtube: Peepshit Studios)
Past: 1991 325ix Coupe Turbo / AP2 05' S2K / 981 Boxster/ 2007 Z4MC/ S13 240SX/ 2002 S2000/ 2004 350Z/ E39 1999 528i/ E46 2004 SC 325CI/ E30 1989 325i Vert/ 1987 E24 635CSI/ 2012 135I
      11-16-2017, 08:24 PM   #7
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
It might be worth checking your VIN here. Who knows, if you are under the recall, they may cover it even though it may not be the same issue. Probably not, but some folks get lucky from time to time.
http://www.zpost.com/forums/showthread.php?t=1024175
There is also this emulator, but if the issue is the actual ACSM module, this wouldn't work, either.
https://www.ebay.com/itm/16085484439...84.m1439.l2649
Salty
      02-16-2018, 09:53 AM   #8
jabramson
Drives: 2006 Z4 Automatic
2006 z4 e85 occupancy sensor now under extended warranty
I don't know if all my complaining the NHSTA and BMW, but I recieved a letter yesterday that the occupancy mat is now having extended warranty on it for 15 years. Brought it to the dealership to get it finally fixed. If you had this repaired and paid for this, you may want to go to the BMW site about this. I'll attach copies of my letter.
Here's one question though. They are trying to tell me I need the seat belt replaced because it's also throwing a code. I've read in places that disconnecting the seat harness and the occupancy mat going bad can throw this code and will reset when the occupancy sensor is bad. They want over $300 to replace the seat belt sensor. What do I do? Will it reset after the mat is replaced. They're telling me the seat belt sensor has nothing to do with this and won't stop the display on the dashboard of the error. Meanwhile, the seat belt doesn't give an alert when not fastened at all. But is that because of the occupancy sensor being bad? Worst would be if I have the seat belt replaced later it would cost about $100 more at the dealership. I'm inclined to not have the dealership replace the seat belt sensor.
I'd appreciate any thoughts on this seat belt sensor issue.
