02-12-2015, 11:00 AM | #23 | |||
Rep 410
Thanks for the offer for stock parts, but they are accompanying the vehicle purchase so I'm good there. Anyway, I was hoping to simply swap mufflers and airbox (that is also aftermarket) and pass visual. But now that I've learned the sniffer may be tricky to pass as well, I'll give the easy route a try. Thanks a bunch guys - this was informative. I look forward to being more active on this board once I get the car (next week). |
02-12-2015, 12:26 PM | #24 |
Rep 1,130
Post pics when you get it!
02-12-2015, 01:17 PM | #25 |
Rep 268
I just got back from my local dealer (Canada). They are charging just under $17 a piece for the header gaskets and $2.38 per nut (x18) for the headers.
Just shy of $145!!!! |
02-12-2015, 01:51 PM | #26 |
Rep 1,443
Whenever I need something quickly and can't wait to get it from Tischer I'm always blown away by the crazy ripoff that buying from my local dealer is. Even after my jaw drops and they say, "ok, we'll knock off 10%". For fasteners and gaskets usually at least four times what realoem says and twice what Tischer charges.
02-12-2015, 02:30 PM | #27 |
Rep 2,782
Thanks. My mind and keyboard don't always sync up .
02-12-2015, 02:31 PM | #28 |
Rep 2,782
A lot of companies sell a header install kit for around $90-100 USD. I would try ECS Tuning, Bimmerworld, etc. International shipping may be a problem though.
02-12-2015, 10:08 PM | #29 |
Rep 410
02-20-2015, 06:47 PM | #30 |
Rep 1,130
I've seen countless times on header install pictures where the cams cover (or valve cover as some people call it) comes off. Is it this required? Because if that's the case, won't we need a gasket for that as well?
02-20-2015, 07:28 PM | #31 |
Rep 268
I think you're talking about the plastic cover that goes over the plugs, coils, etc.? That's mostly a cosmetic piece and doesn't have a gasket. It is removed so people can re-arrange some of the o2 sensor cabling.
02-20-2015, 07:28 PM | #32 | ||
Rep 407
02-20-2015, 09:09 PM | #33 |
Rep 1,130
Ah that's great news that I don't need another gasket. I just got my headers today but i need to order the parts. UntzUntzUntz $66 is cheap. I was gonna go with ECSTuning but BMWparts might be cheaper..
Anyway thank you both for confirming that. Untz when will you do your install? I got my euro headers and S pipe ready to go but I need all the parts. I think I'm just gonna purchase everything you listed as I don't wanna run into any surprises while installing it all. |
02-20-2015, 09:17 PM | #34 |
Rep 25
I'm surprised people are struggling so much with CA smog.
All you have to do is make the computer happy these days. There is no sniff test. If you are doing headers, you should certainly be doing a tune. Have the tuner repress the O2 sensor voltage readings. It will show as ready and error free. Unless the smog guy is an ass and fails you for visual. |
02-21-2015, 01:23 PM | #35 |
Rep 1,130
I've also read that the O2's won't need to be extended. I have a section 1 from DKF which already comes with the EGT and O2 bungs. I've read a few threads from different forums where they successfully used their OEM wires and were able to reach the bottom of the car on S pipe O2 bungs. My euro headers came with the O2 sensors. Should I use those, should I use my OEM ones, or should I buy new ones?
02-21-2015, 01:29 PM | #36 | |
Rep 25
02-21-2015, 07:16 PM | #37 |
Rep 1,130
Yea exactly, I'll do just that. As for the O2's, I'm thinking mine are just fine so I'll use my OEM ones. All parts ordered. Thank you for your help OptionlessM. I'll continue posting on your thread Untz as this is the same topic.
02-22-2015, 02:46 PM | #38 | |
Rep 407
And this might be a silly question but what kind of bungs are needed for the EGT and O2 sensors? I know they're universal standard size but the euro bungs seem to be with an angle? |
02-23-2015, 02:18 AM | #39 | |
Rep 1,130
I haven't seen my US headers yet so I can't compare the bungs to the euro ones. There's a thread I recently read talking about welding the correct type of bungs on the U.S. part. Here it is: http://www.bimmerfest.com/forums/sho...d.php?t=414504 |
02-23-2015, 03:06 AM | #40 |
Rep 1,130
I was too focused on the front of the exhaust system that I completely forgot to order the 2 gaskets that connect the S pipe to the X pipe! I ordered both just now for $13.03 shipped, but I noticed the brand is CRP. Is it critical that these 2 gaskets are OEM or would the CRP be fine?
02-23-2015, 04:17 AM | #41 | ||
Rep 407
Down to business, I actually saw that thread earlier today, doesn't specify if the o2 bungs go with an angle BUT I found this http://www.bimmerfest.com/forums/sho...=419474&page=2" rel="ugc" target="_blank">http://<a href="http://www.bimmerfes...474&page=2</a> on post #46 he's using 90 degree bungs and it doesn't seem be showing any CEL lights. On page 3, user Kav confirms it on his setup. Quote:
DAMN YOU CALIFORNIA SMOG! I'd rather spend the time and money to extend the o2 wires long enough into someone else's stock ///M... Man I should sleep. Goodnight people. |
02-23-2015, 09:08 AM | #42 | |
Rep 1,443
02-23-2015, 10:25 AM | #43 | |
Rep 1,130
02-23-2015, 10:26 AM | #44 |
Rep 1,130
