      11-30-2014, 02:34 PM   #1
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Front M vs Non-M
The front suspension of the M and non-M are essentially the same aren't they? Based on the e46? So any wheel fitment used on an M would work for a non-M, right? I'm trying to decide proper wheel offsets and don't want rubbing for 18s. Car will be on Coilovers. So, I'm thinking the 235/40-18 8.5 et 35. Seems like the safest yet still aggressive option.
      11-30-2014, 03:45 PM   #2
dorifto88
Drives: 88 Nissan Pathfinder
seems possible, though i personally have no experience with a non-m. what kind of wheels are you getting?
      11-30-2014, 04:00 PM   #3
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
I'm thinking the new Apex PS-7s. Light weight and classic.
      11-30-2014, 10:39 PM   #4
3002 tii
3002 tii's Avatar
2282
I rubbed with a 235/40 on a 8.0 et34 on stock suspension because the tire was too tall. You're better off running a 255/35 on 8.5 with high 30 to low 40 offset. Worst case you might need to pull the strut pins and dial in some negative camber.
Follow for latest mods
      12-01-2014, 06:21 PM   #5
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Damn, do you know what you were rubbing on? Fender liner around where the bumper and fender meet each other?
Interesting to see the Z4 and Z4M have differed OE tire profiles. Non-M is 225/40 & 255/35 while M is 225/45 & 255/40.
-Matt
| Z4M Build Thread | @violetnites | flickr |
      12-01-2014, 07:09 PM   #6
3002 tii
3002 tii's Avatar
2282
That's exactly where it was rubbing, where fender and bumper meet.
      12-01-2014, 08:02 PM   #7
tiltmode43
I plead the 5th.
tiltmode43's Avatar
@sdcoupe - How low do you plan on dropping the car? ^^^ This is where I had some rubbing issues as well but your desired ride height is going to have an effect on things as well.
-Matt
      12-01-2014, 08:05 PM   #8
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
I'm running 255/35 x 18 on 8" ET 47 Style 108's in the front. No rubbing or issues. From clearance measurements I've made I could probably run 265/35 if the brands I run made that size. The strut pins are pulled and front camber is maxed out at -1.4 degrees.
3.0si Roadster with M Sport suspension.
      12-05-2014, 06:56 AM   #9
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
The front suspension is very different between the m and non m...the m uses e36 bottom mounts, the non m uses e46 mounts...for clearance purposes they won't be drastically different though
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      12-05-2014, 09:32 AM   #10
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Probably not too low. I'm just looking to remove some fender gap. I don't want to have to pull pins and change camber. Just drop it a tad to make clean look.
      01-05-2015, 11:07 PM   #11
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
I just had mounted 235/40-18 front on new Apex PS-7 8.5' rims with Michelin Pilot Super Sports with 35 offset. No rubbing! Rears are 265/35-18 on a 9.5' rim with 43 offset. Again, no rubbing! Very stoked. It looks great. Need to put the coilover suspension on now and remove the fender gap.
