      03-21-2013, 11:25 AM   #1
ludoZ4
Drives: Z4 3.0si
manual mode ignore me
Hi buddies,
I have a problem with my Z4 3.0si automatic with paddle shift.
When i'm in Manual mode, it sometimes shift as if it was in automatic mode.
And sometimes, when i'm on sport mode(SD), it shit to normal mode (D). I made a video, i'll post it on youtube, so u could see.
What is going wrong ?
      03-21-2013, 12:10 PM   #2
SwissArmy
Why so serious?
SwissArmy's Avatar
Drives: BMW Z4; BMW X5; BMW 733
So, you have an SMG? I have an SMG transmission. When I put it into manual, it ONLY downshifts for me.
      03-21-2013, 12:15 PM   #3
ludoZ4
Drives: Z4 3.0si
No, itīs not SMG, or i don't think so
      03-21-2013, 01:38 PM   #4
SwissArmy
Why so serious?
SwissArmy's Avatar
Automatic, Manual, and Paddle shift? I thought that meant SMG. Do you have a clutch pedal? ()
      03-21-2013, 02:07 PM   #5
Pete C
Pete C's Avatar
Drives: '08 Z4 SI
I've got 3.0 Si with auto trans and it needs to have the shift lever moved to the left to enter manual mode. It will then hold in gear until stoping but also has throttle kick-down and upshift at redline. It is really just a gear holding feature for cornering and with torque converter locked feels like a manual gearbox. The sport button changes the shift points but is still full auto like in "D" unless the lever is moved over. Paddles are just for convenience and work secondary to the selected mode.
Hope this helps and make some sense!
      03-21-2013, 02:20 PM   #6
SwissArmy
Why so serious?
SwissArmy's Avatar
Learned something new. I hope this helps OP
      03-21-2013, 02:31 PM   #7
ludoZ4
Drives: Z4 3.0si
Hi buddies.
You're totally right Pete C, but you also have a full manual mode on auto trans, when the shifter is moved to left, it don't have to shift gears automatically
      03-22-2013, 10:06 AM   #8
ludoZ4
Drives: Z4 3.0si
but that happen sometime, not all time
      03-22-2013, 07:34 PM   #9
3point0
3point0's Avatar
Drives: 2005 z4 3.0
2006 Audi S4 Avant  [0.00]
2005 BMW Z4  [5.67]
SMG was only available for '03 and '04 (maybe for '05 too) and was discontinued after that. The auto box (like mine) up to the facelift for '06 was just a regular auto with steptronic mode where you can shift up or down using the gear lever. In 06 they added paddle shifters to the auto box. In all cases, the auto box gets sharper response and later shift points with teh sport button engaged.
Is there a link to your youtube video?
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector
OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | custom speedo logos | stubby antenna | polished exhaust tips
      03-23-2013, 10:59 AM   #10
ludoZ4
Drives: Z4 3.0si
i lost it :/
i'll make an other one
      04-13-2013, 07:15 PM   #11
ludoZ4
Drives: Z4 3.0si
sorry for the music, i did'nt know my friend was filming
      04-17-2013, 02:54 PM   #12
ludoZ4
Drives: Z4 3.0si
nobody can help ?
      04-17-2013, 04:25 PM   #13
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Originally Posted by ludoZ4 View Post
nobody can help ?
From what I gather in this thread, this is the SMG transmission, and very few (if any) of us have that transmission. If this is indeed the SMG, you might get more input from an E46 M3 crowd since the SMG box was used quite a bit on the E46 M3.
If I had to guess, I'd think the module/controller has issues, or the shift lever isn't triggering the right mode (manual vs. auto) which could be a contact/switch issue in the shifter mechanism. Since it works sometimes, and since modules using fail 100%, it may be a shift level/contact/switch issue.
Access to a diagnostic tool to read any codes the ECU is recording would go a long way to helping you figure out where the issue is.
      04-17-2013, 07:58 PM   #14
jophish17
jophish17's Avatar
58
Drives: Z4MC
^ I think it's not the same as the E46 M3s SMGII - I think it's closer to the old E36 original SMG box so they might be better able to help you
      04-17-2013, 07:59 PM   #15
2286
It's not smg, smg was only available in early model Z4. Late model autos are similar to the tiptronic trans from the e46 non-m.
      04-17-2013, 10:08 PM   #16
Finnegan
Finnegan's Avatar
Ok. Did not know the SMG years.
Still think it's either a module or some kind bad contact or component in the shifter module/mechanism. That's my best guess. Diagnostic scan is best way to not guess.
      04-21-2013, 02:18 PM   #17
ludoZ4
Drives: Z4 3.0si
Indeed, it's not a SMG, just automatic with shiftpaddles.
