      11-09-2014, 08:56 PM   #1
Spaceman Spiff
Drives: R8, 996 C2, Z4MR (sold)
Will these fit a Z4M?
Edit: Looking for a winter set. Would Style 106 wheels (17x8, 47mm offset) fit the Z4MR? I am assuming I can mount 225/50R17s on the rims (correct?)
This is an example of the wheels
http://www.ebay.com/itm/BLACK-BMW-Z4...3D251695558425
      11-12-2014, 10:33 PM   #2
Spaceman Spiff
Anyone?
      11-13-2014, 07:48 AM   #3
DaveZ
DaveZ's Avatar
Drives: 2017 M2
17" rims may or may not clear the front calipers on the M, it all depends on the design of the inner barrel. There is probably no way to tell in advance unless you test them yourself or you find someone that has already done so with those exact rims. And if they do clear the calipers, it is going to be so tight that any wheel weights will have to be clipped to the outside- weights on the inside of the barrel will just get flung off by the calipers. I know in the distant past, TireRack listed a couple of very specific 17" packages for the M that they had tested, not sure if they still do.
DaveZ - http://www.zeleznik-klein.com/m2
2017 M2, Mineral Grey, DCT
      11-13-2014, 08:36 AM   #4
Spaceman Spiff
Thanks Dave! They do recommend a number of 17" wheels, which is why I thought these might work as well. I guess I'll just err on the side of caution and go with 18"!
