11-23-2017, 09:12 AM | #46 |
Rep 1,794
Drives: E86 3.0si
Gotta disagree. While flat spotting is not as much an issue with low aspect ratio tires, many 65, 70, and 80 series radials certainly are prone to storage flat spots.
11-24-2017, 02:01 AM | #47 |
636
Rep 3,124
^WHS
I had 60s on my MR2 that I would store when I was back in Chicago and it took a week of hard driving to get them back to being round in the spring. Subsequent years of storage I put it up on stands and took the wheels off.
12-11-2017, 07:44 AM | #48 |
Rep 500
I lay down roofing tar paper on the floor to keep the moisture down in my garage, as a roll of that paper is cheap.
Pull the battery and it comes into the house. Car sits on crappy tires on the original 18" wheels, so not caring about that. |
12-12-2017, 09:05 PM | #51 |
Rep 34
12-13-2017, 06:28 AM | #52 |
dances with roads
4722
Rep 4,096
12-27-2017, 11:41 PM | #54 |
Rep 25
I'm with Clubracer here in Atlanta. It gets cold, but not really cold enough to store the car. I just keep it in the garage with a tender if I am not going to drive it for a couple of weeks.
12-28-2017, 10:58 AM | #55 |
Rep 15
Here in NH we are cold and snowy. Right now it's 4 degrees with a wind chill of 9 below. Car is in a climate controlled 100K sq ft facility with 500 other cars. All have tenders and pads under the tires. Car's happy, I'm happy. Pull it out in April.
2018 X3 3.0i M sport - mine
2014 428i- conv - Hers |
12-29-2017, 09:18 AM | #56 |
dances with roads
4722
Rep 4,096
Are you fabulously wealthy, or is that a shared space?
12-31-2017, 03:34 PM | #58 |
Rep 4,057
a couple of pics for the topic:
if you look closely you may be able to see the battery tender behind the driver mirror with the status light glowing green while the car waits patiently for spring. Until then, the red Honda blower will be seeing use (and I hope not too much).
Huz-Z
wdb4721.50 |
12-31-2017, 04:29 PM | #59 | |
dances with roads
4722
Rep 4,096
01-02-2018, 05:09 AM | #61 |
Rep 18,734
No worries. It's 4 deg. here in central Virginia today. I'll just walk outside, startup the si Coupe crank up the heated sport seats and enjoy the 24,000 ft-lb/deg. drive to work.
01-06-2018, 08:36 PM | #62 |
Rep 72
Drives: 2008 E86 Z4 MC
Winter hibernation
Fresh oil, full tank, CTek & cover
02-04-2018, 10:40 AM | #63 |
Rep 1,345
Drives: 04 Z4, 18 X3 M40i
My routine for the last 13 winters has been oil change, top up with ethanol free gas, stabilizer, breathable cover, climate controlled storage with lots of rodent protection, maintainer on the battery, detail before going away, boost air pressure in tires, fabric softener sheets in cabin and trunk. Goes away in November out in April.
02-04-2018, 08:25 PM | #64 |
Rep 150
