      01-02-2015, 11:41 AM   #1
cheo_7
Puerto Rico
Drives: 2008 BMW Z4 M Coupe
HELP!
Hi guys, I recently bought a set of CSL headers from Donovan. But they I have reasonable dent in them. Is there anything I can do to fix them that doesn't involve cutting them?
      01-02-2015, 11:43 AM   #2
torchmedia
Drives: White Z4MC
Check out his for sale thread on another set of dented headers here:
http://www.zpost.com/forums/showthread.php?t=1065781
A few posts down there is a method to removing the dents that apparently works.
      01-02-2015, 04:57 PM   #3
Steeler
Steeler's Avatar
2429
If that idea does not pan out, although it does sound doable.
Try drilling a couple of holes and trying a slide hammer(dent puller). You will need to weld the hole after and grind but should remove most of the dent
