      10-02-2014, 12:40 PM   #1
dragonfire6
Drives: 06 Z4 3.0i w/Premium Pkg
N52 Starter Replacement... Huge pain in the @$$!
I'm coming from a 350z that I don't remember being nearly as hard to work on but damnnnnnnnn BMW why you gotta do me like this?!?!
It would've taken me about 4 hours to replace it but I broke the crankcase breather hose so I'm on my way to the dealer to pick up a new one ($88).
Tips:
1. I was able to install the new starter without completely removing the I take manifold. Yes, doing so would give you more room but the last couple of connections and hoses looked like more trouble than I wanted to put up with. Probably saved me 45-60mins not disconnecting it completely.
2. The hose connectors that attach the crank case breather hose is now #2 on my list of things I had most in the world. It has this ring that needs to be pinched and then pulled with the power of the incredible hulk. I used a combination of needle nose pliers and cursing to finally remove and effectively break the hose.
Good luck to anyone attempting this. Make sure you buy a 6-pack of your favorite beer because you are going to need a few during and after.
      10-02-2014, 01:33 PM   #2
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
I have a S54, but I removed the entire intake when I replaced my starter. Easy peasy.
      10-02-2014, 05:00 PM   #3
fdagen
Drives: 2006 Z4M Roadster
Nice dude, that's what someone wants to hear after a hard day. Anyway, everything I do on this car seems to take 2x as long as everyone else. It's a love hate relationship. I just go slow. The 6 pack helps.
      10-27-2014, 01:41 PM   #4
3002 tii
3002 tii's Avatar
2285
I removed the intake manifold. Was intimidated at first but found that it was pretty straight forward and made the job much easier.
Follow for latest mods
      12-06-2014, 02:37 PM   #5
Grant01
Drives: 2006 Z4 M Coupe
BMW and easy starter replacements are never a line that go together.
      12-09-2014, 07:32 PM   #6
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
Tighten a hose clamp over those crankcase vent hose connections to get them to release grip with lowest chance of breaking
