      02-24-2014, 10:03 PM   #1
Steenos
Drives: 2007 Z4M Coupe
2021 BMW M240i  [0.00]
2007 M Coupe  [0.00]
Antenna help
So I was trying to install a stubby antenna and things didn't go so well. Took the stock antenna off with a set of pliers.
I noticed the bolt for the stock antenna was messed up(I don't know the proper terminology) after removing the antenna.
The stubby antenna came with inserts. I'm just wondering how to remove the stock insert so that I can install the insert that came with the stubby.
Hopefully I'm not rambling and someone knows what I'm talking about. Thanks.
2021 m240i on order
      02-27-2014, 07:14 PM   #2
pungo
pungo's Avatar
Did the male threaded part not come off with the antenna? If so, you could thread 2 nuts onto it and tighten them against each other. That should allow you to loosen it and remove it.
      02-27-2014, 09:11 PM   #3
Steenos
2007 M Coupe  [0.00]
Negative the male threaded part did not come out. I found a thread on how to remove the antenna all together. I may just have to remove it all together to get the threaded part out.
2021 m240i on order
      03-02-2014, 07:04 PM   #4
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
Same thing happened to me...I had to replace the base which turned to be a bit of a pain in the ass haha
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      03-03-2014, 08:21 PM   #5
Steenos
2007 M Coupe  [0.00]
Where did you find a replacement base?
2021 m240i on order
      03-03-2014, 11:44 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
Does it look like this?
      03-04-2014, 08:09 AM   #7
Steenos
2007 M Coupe  [0.00]
Yup. Thanks stickmon.
2021 m240i on order
      03-16-2014, 06:31 AM   #8
SwissArmy
Why so serious?
SwissArmy's Avatar
This is exactly what I got. And then I was slapped with HEAVY customs fees! (Around $70 :|)
Canadian buyers should speak to them before ordering. They can figure out an alternate way to avoid custom fees
