07-06-2009, 04:53 PM | #397 | |
Rep 606
I'm most curious to hear what this sounds like a cruising speeds on the highway from inside the cabin. Are videos of this planned? I'd be interested in hearing what it sounds like while holding the revs constant at 2000, 2500, 3000 and 3500.
07-06-2009, 05:38 PM | #398 | |
Rep 857
Intro pricing is $899. We are only making 25 of these so I would get a list going if any of you want it.
yep 8whp and 7ft/lbs. Quote:
07-06-2009, 06:01 PM | #400 |
Rep 857
07-06-2009, 07:55 PM | #401 | |
Rep 1,709
The sound is Pure Sex (very Deep and no rasp) ...I've heard quite a few exhaust on the Z4M and this is the reason why i picked this system (with Hp and Tq to boot)...
Live as if you will die tomorrow, but learn as if you will live forever." M.G
07-06-2009, 11:26 PM | #402 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Any word yet on the noise readings?
You have to be 100% behind someone before you can stab them in the back.
David Brent |
07-07-2009, 01:41 AM | #403 |
Rep 1,709
Eloy and i just met an hour ago to measure the db meter and i'm sure he'll post the readings and the vid...be ready to order the exhaust
07-07-2009, 01:42 AM | #404 |
Rep 1,709
07-08-2009, 06:03 PM | #405 |
Rep 857
I have the test on video but it doesnt want to upload right now for some reason. The test was done at about 20" from the exhaust tip at a 45 degree angle. In nuetral, revved to 7500rpm, the db is 112. At 4900rpm its 97-98db. At 6000rpm its hovering at the 100db range.
07-08-2009, 11:44 PM | #408 | |
M Slut
18
Rep 564
David Brent |
07-09-2009, 11:29 AM | #409 |
Rep 857
Its the axle back only. The stock piping is VERY well designed and I couldnt find a cost effective way of improving on it. We have dynoed several aftermarket tubing without significant improvements in performance. Our axle back uses two small resonators.
07-09-2009, 01:19 PM | #410 |
Rep 259
So I make sure I understand... these are stainless and the entire unit will be polished.. correct? Thanks, Chuck I
07-09-2009, 01:26 PM | #411 |
Rep 857
07-09-2009, 03:32 PM | #413 |
Rep 857
Held at 4500-4900rpm the reading in nuetral hovers 98db. I dont have any readings during cruising, etc as there was an LASD deputy watching us very closely as we did this test. This system does fall into our GT series category so quiet wasnt one of our main priorities.
07-09-2009, 06:06 PM | #414 | |
Rep 104
~Ryan |
07-09-2009, 06:20 PM | #415 |
Rep 857
07-09-2009, 10:06 PM | #416 |
Rep 161
I got these readings from Edmunds test drive of an 06 M Roadster. It doesn't state how they obtained these readings, so I don't know how valid they are.
Db @ Idle: 52.5 Db @ Full Throttle: 83.4 Db @ 70 mph Cruise: 71.5 Here is the link. http://www.edmunds.com/apps/vdpconta...4/pageNumber=5
ZHP knob/Zeckhausen CDV/ESS Tune/More to come |
