      11-22-2012, 11:27 PM   #1
Krypptic
Drives: E92M, GT3
S-Pipe for Z4M
Other than supersprint, does anyone make an s-pipe for the z4m?
I have supersprint x-pipe and powerloop mufflers installed already.
I have on order the fabspeed headers and evolve-r tune.
My shop is telling me they can fab them for about $400, but I would rather buy a set that are ready to go.
The supersprint are too expensive and no one keeps them in stock.
Another option, is that I can have the shop gut the existing s-pipe cats and go that route.
Any suggestions?
      11-22-2012, 11:56 PM   #2
dorifto88
Drives: 88 Nissan Pathfinder
I'm probably wrong but I think supersprint is your only option unless you want to do a custom S pipe. for reference I would also look up full motor Union I think it's called they did a custom exhaust for a carfrom the headers all the way back. is your intention to go fully catless?
      11-22-2012, 11:58 PM   #3
dorifto88
http://www.fluidmotorunion.com/archives/tag/z4m
      11-23-2012, 12:10 AM   #4
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
http://www.zpost.com/forums/showthre...419023&page=25
      11-23-2012, 12:33 AM   #5
dorifto88
Originally Posted by JeffchaPz View Post
lol i had no idea that was still going on.
      11-23-2012, 12:58 AM   #6
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I hope you go for a catted/resonated S-pipe...because otherwise with the headers, you're going to get a RIDICULOUS amount of rasp
Been there, done that. Cool for volume/flow, but not rasp
Sold my SuperSprint unresonated S-pipe a while back and put the OE section1 back in to control the God-awful rasp.
      11-23-2012, 05:53 AM   #7
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
How do you find the rasp now?
I'm doing headers in the spring & that's my one concern.
I don't mind a bit of drone, but I hate rasp.
      11-23-2012, 08:28 AM   #8
Krypptic
Drives: E92M, GT3
I've seen that thread, but its been going for 2 years and I still see no ETA as well.
No pricing either?
      11-23-2012, 08:49 AM   #9
Krypptic
Drives: E92M, GT3
Do you have a clip of how your car sounded? I have tried listening to videos on you tube to see how it will sound but only found one z4m fully catless, and it sounded great. Thing is, it didn't mention if resonators were used.
      11-23-2012, 10:59 AM   #10
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Use resonators if going uncharted. Like Mfanatic said, rasp is awful w/o.
Aero turbine resinators, or similar, in a custom section S pipe section would work.
You might want to try searching E46 M3 forums for other ideas on this (larger base/volume of cars).
      11-23-2012, 03:57 PM   #11
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
I have CSL headers, I fabricated a custom catless S pipe out of a E46 M3 section 1, OEM X-pipe and OEM mufflers.
It's not really loud, no drone but it's rasp festival. I kinda like it. The only thing with a catless car : it smells!! You can't stay in traffic with windows open. I think I will put OEM S pipe back on the car with my BMS X-pipe.
If you want to do a custom S -Pipe with no rasp, you can buy Aero Turbine resonator AR-20 or AR-25. A lot of guys use them on E46 M3.
http://www.custom-performance.net/pr...idCategory=253
      11-23-2012, 03:59 PM   #12
Gt4
Gt4's Avatar
I will also make a custom S Pipe with 2 resonators from an E46 M3 soon withthe o2 and EGT sensors bungs in it. I will post pics when finished.
      11-23-2012, 04:30 PM   #13
habitat412
Drives: 2008 Z4 M Coupe
In the same boat. Have CSL headers installed and looking for an S pipe. Picking up the RE X pipe and have RPi's installed. Will DKF's S pipe work for us?
      11-23-2012, 08:03 PM   #14
mfanatic325
///M-fanatic
Taiwan
193
With the OE section1 back in, the car quieted down quite a bit; very noticeable difference. And there was approximately a 30% reduction in rasp
I recall that when I had everything free-flowing, I registered a maximum of 106dB @ the track, blowing by the sound check hut on purpose
I'll try to find a vid and post it up here. Look for an edit soon.
edit: can you view this vid? If so, just listen for the cold startup at the very beginning, and then if you can, skip to the end for a 1st gear redline through a small underpass (at 7:13 to be exact):
https://www.facebook.com/photo.php?v=10150965087107856
Also, from a huge "Exhaust 'Fest" we had locally, here is a compilation of many different setups. In the following video, my car's recordings can be found at 1:16 (startup + mid-rpm revs), 6:00 (soft pull), and 8:16 (hard pull).
http://www.youtube.com/watch?feature...&v=Ar78IVHcbRs
In both videos linked above, my setups were the same:
- JVT/"eBay" headers (a.k.a. SuperSprint v1 knock-offs)
- OE section1
- SuperSprint unresonated X-pipe
- SuperSprint race muffler cannisters
Hope this helps!
      11-23-2012, 10:46 PM   #15
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
A custom S-pipe with Aero Turbine resonators won't sound raspy, will it? I think that what e46 m3 "rasp pipes" use to eliminate rasp actually
      11-24-2012, 12:06 AM   #16
mfanatic325
///M-fanatic
Taiwan
193
It should be pretty nice with the Aero resonators put in
      11-25-2012, 01:41 PM   #17
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
i have a custom fabbed section 1 with some small resonators and it keeps the rasp down quite a bit.
i have the fabspeed headers, RE x-pipe and arqray mufflers.
it was 400 for the section 1 pipe if that helps.
'07 MCoupe
lots of mods
      11-26-2012, 08:42 PM   #18
txz4
txz4's Avatar
59
Drives: 2006 M coupe
Dave has only one large aero turbine resonator in his system, nothing else (no cats). No rasp at all.
      11-26-2012, 09:50 PM   #19
Krypptic
Drives: E92M, GT3
How do you know which size to get? I checked the m3 forum and some used the ar20 others the ar25. The difference being 2 inch v. 2.5 inch.
I can do this one of two ways, have a whole pipe fabbed, or just cutout the cat and replace it with resonator. Any suggestions?
      11-26-2012, 09:59 PM   #20
ZStig
279
I like that idea. Even less weight
      11-27-2012, 09:49 AM   #21
txz4
txz4's Avatar
59
to dig up an old thread:
http://www.zpost.com/forums/showthread.php?t=646775
A diagram to show what it looks like (Daves setup) he now has no cats at all, i believe in the videos in the thread he still has US headers. He now has Euros, the Sound is different and there is still no drone really. Much more rowdy sounding now!
      11-28-2012, 03:47 PM   #22
IDLE TIME
IDLE TIME's Avatar
Drives: still searching
Yes they will have a s pipe with cats proto on forum members car now no problems. We are waiting to hear from vendor. Should have some information soon. Please PM me on questions.
