10-04-2017, 12:44 PM | #67 |
Rep 431
Hi all - Providing some stats on my square setup as I have been asked a couple of times for more information. PM me if more info is needed and hope this helps!
Wheels: APEX Arc-8 18x9.5 et35 Tires: Toyo Proxes R888R 265/35/18 (these run big - more like a 275) Suspension: TcKline DA Coilovers Spacers: Front None | Rear 12mm Camber: F: -2.8 (Camber Plates) | R: -2.0 Toe: F: 0 | R: 1/8 Total Caster: Maxed Out
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo |
10-04-2017, 02:14 PM | #68 | |
Rep 2,650
Thanks for providing your fitment info, do you mind if we share your photos and specs with other Z4 customers looking for advice?
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
10-04-2017, 02:51 PM | #69 |
Rep 431
Thank you and absolutely, you're more than welcome to!
10-09-2017, 12:19 PM | #70 |
Rep 6,701
Great, much appreciated!
10-30-2017, 02:46 PM | #72 | |
Rep 6,701
Hope this helps!
10-31-2017, 05:41 AM | #73 |
Rep 199
Thanks for the reply. Mine is the 380mm kit. What does a brake template look like, and how do I get one?
Do you know of any ARC-8 specifications that will definitely clear my bbk? Perhaps in 19", which is the size I'm currently running on. |
10-31-2017, 01:48 PM | #74 | |
Rep 6,701
The 19" will require the same spacer, since the clearance issue is with the spokes, rather than the barrel. Hope this helps, let me know if you have any additional questions!
11-03-2017, 08:41 AM | #75 | |
Rep 199
11-20-2017, 03:18 PM | #76 |
Rep 2,650
It sure is! That kit will clear the following ARC-8 sizes:
18x9.5" ET22 18x10" ET25 18x10.5" ET27 All 19" sizes The 18x9.5" ET35 ARC-8 would require at least a 12mm spacer to clear, making it an effective ET23, in which case you would just use the 18x9.5" ET22. Our 18x9.5" ET35 EC-7 wheel will clear the 6-piston 380mm StopTech kit with no issues, however.
11-21-2017, 08:10 AM | #77 | |
Rep 199
12-11-2017, 02:38 PM | #78 |
Rep 6,701
TIRES NOW AVAILABLE
Add tires to your ARC-8 wheels with free in-house professional mounting, balancing, and quality control inspection. Check out our tire selection and feel free to contact us for a recommendation.
05-17-2018, 04:33 PM | #79 |
Rep 6,701
Now available due to popular demand, red APEX centercaps! Use this link to check them out and place a pre-order.
07-31-2018, 10:06 PM | #80 |
Rep 94
ApexRaceParts
Still recommend the following for stock fitments? (Concave F&R) 18" Staggered: F: 18x8.5" ET38 (Profile 1) - 235/40-18 R: 18x9.5 et22 (Profile 3) - 265/35-18 or 275/35-18 Any experience fitting these over bilstein B12 setups - that's bilstein dampers paired w/ Eibach prokits. Edit - I'm talking "stock fitment" being no camber plates, spacers, etc. Cheers! Last edited by winnipegz4m; 07-31-2018 at 11:53 PM.. |
08-01-2018, 02:49 PM | #81 | |
Rep 6,701
08-02-2018, 09:37 PM | #82 |
Rep 94
Expert@ApexRaceParts
Perfect - cheers! For Canadian orders - should I order through ApexRaceParts.com, or do you have a Canadian dealer that you can recommend that carries inventory? |
08-03-2018, 12:42 PM | #83 | |
Rep 6,701
Thank you for reaching out, we do not have any stocking dealers in Canada at this time. We would recommend purchasing directly through our website. Feel free to PM us if you have any additional questions! Best, Max
08-28-2018, 01:56 PM | #85 |
Rep 6,701
We do have some Group Buys running at the moment, including a deal on 17" ARC-8 wheels. You can view all our current group buys here: https://www.gangup.com/apex
09-16-2018, 10:56 AM | #86 |
Rep 94
Expert@ApexRaceParts - bonus questions - is there a 19 inch ARC 8 setup that fits w/ stock suspension - i.e.: without camber plats, spacers, etc.? Just debating 18 vs 19...
09-17-2018, 01:26 PM | #87 | |
Rep 6,701
Front: 19x8.5" ET35 with 235/35-19 tires Rear: 19x9.5" ET22 with 275/30-19 tires - Direct fit with no spacers or modifications required This fitment is also available in 18" as well: Front: 18x8.5" ET35 with 235/40-18 tires Rear: 18x9.5" ET22 with 275/35-18 tires Let me know if you have any other questions!
11-07-2018, 12:19 PM | #88 |
Rep 6,701
Strong, light, affordable. Choose three.
