      02-14-2014, 08:03 AM   #1
Geauxkart
Geauxkart's Avatar
13
Drives: 2007 Z4 M Coupe Sepang
For those with O2 CEL issues / Or catless even?
I bet this will help. Their old version won't work on our cars, but I bet the new version would.
http://www.o2simulator.com/
I'll be the guinea pig if someone wants to sell me an OEM section 1 to modify (CHEAP...)? I'll bypass the cats with a test pipe and see what happens.
Betcha you could run catless.
Thoughts?
      02-14-2014, 08:21 AM   #2
Steeler
Steeler's Avatar
2429
Thoughts?
Saw this too, worth a try for 100 bux.Even if you are running cats and still getting the CEL this would be an easy fix.
      02-14-2014, 09:25 AM   #3
itdnwiwbp
Drives: 330iZHP
I saw that someone was getting a CEL after installed the DKF cats. I guess I might have to go this route but it'll be awhile before I get around to it. Would love to know if these work.
      02-14-2014, 12:29 PM   #4
z4msteve
Drives: '07 Z4MC
If you're running catless why wouldn't you invest in a tune that could take care of this for you as well as make your car utilize the extra potential? To me that seems like the way to go.
RPI scoop, Euro headers, SS PowerLoop, Epic race tune, AKG motor/trans mounts, Turner camber bolts
      02-14-2014, 12:32 PM   #5
z4msteve
Drives: '07 Z4MC
Also, after some reading on their site, "One simulator per downstream oxygen sensor." so more like a $200 fix.
      02-14-2014, 06:51 PM   #6
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
I have my OEM section 1 for sale - $450.
      02-18-2014, 10:45 AM   #7
p1nk50ck
HNIC
Drives: Z4M Coupe
i had this on my straight-piped IS300 (all 3 cats removed) and it worked perfectly. the only downside is that you have to tap into wires going into the ECU. It's not hard, but it's kindof a "permanent" mod, since you're cutting/tapping into wires that aren't easily replaced.
it allowed me to pass VA emissions with no problems using the ODB-II machine (except visual inspection of a cat which they never do, and blue smoke/nose sniff, which they never do)
my last car was an Audi a4 2.0T, which I also ran catless, this time i used software (APR Stage II+) to get a good bump in power and also remove the CEL. This also passed with flying colors, and had the added benefit of fuel savings, and power.
      04-15-2014, 10:53 AM   #8
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Anyone try this? Curious if it works.
      05-20-2014, 02:24 PM   #9
daveysew
daveysew's Avatar
Drives: '91 318is/'05 Z4 SC/'18 440ix
Bump to see if anyone has tried this yet.
      05-20-2014, 03:33 PM   #10
Steeler
Steeler's Avatar
2429
Go ahead be the guinea pig
I will be trying it but not until I store the car in the fall
I have a CEL unrelated to my supercharger.
I installed a header this winter and the SES light turned on after 100 kms
      06-02-2014, 12:13 PM   #11
C-los
Drives: 2013 M3
If you still need the Section one, My vehicle came with a section one and the bottom cats already chopped off and test pipe welded. I'll Check if my shop still has it laying around if you still want it. Just pay shipping and you can have the piping free. Let me know if you still need it.
      06-05-2014, 10:34 AM   #12
C-los
Drives: 2013 M3
Yeup, my shop still had my section 1's layig around with test pipes already on it. Welcome to have them if you pay shipping, i dont 'want any money. Just donating a part to help out
