      07-18-2014, 10:44 PM   #1
bjbstewart
bjbstewart's Avatar
Drives: 2007 BMW Z4MC
FS: Z4M M3 S54 Fabspeed Headers by VAC
I'm moving and decided it will be easier to sell my VAC Fabspeed headers. They were on the car for a few thousand miles, but I'm in CA and have decided it's a bit of a bother. The were removed for smog and I've decide to sell rather than put them on again, although with the Evolve tune, they made a HUGE difference.
They are $1095 new, and were Jet Hot coated (~$500), and are in excellent condition as you can see from the picts. The website has a bunch of additional info, see:
http://store.vacmotorsports.com/fabs...ine-p2637.aspx
Highlights include:
  • High quality 14-16 gauge, T304 stainless steel, with the precision of computer controlled mandrel bent primary tubes
  • Excellent fit and high precision welds that Fabspeed is known for
  • Allows use of original S54 exhaust studs
  • 38mm Primary runners with 50mm secondaries for excellent torque as well as top RPM HP gains
  • Includes all new, needed gaskets, including for head and section one
  • Fabspeed's signature 3-into-1 high velocity merge collector for improved exhaust scavenging
  • Built in Secondary O2 spacers
  • Excellent power gains ( Fabspeed Dyno tested at 24WHP and 24 Ft/lbs with performance software)
  • Proper clearance and location of O2 sensor bungs & EGT sensor
  • Fit both the SMG and 6speed manual transmission cars
  • 3.5lb savings vs. stock exhaust manifolds
Website says these fit:
-'01-06 E46 M3,
-'01-02 E36/7 Z3M (S54 powered models only)
-'05-08 E85/E86 Z4M vehicles (Some heat-shield trimming may be needed)
$995 shipped to the lower 48. PM me if you have any questions!!
[SIGPIC][/SIGPIC]
      07-18-2014, 11:02 PM   #2
fullerra
fullerra's Avatar
14
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
I have the fabspeed headers non-coated and say that they are one of the best mods I've done so far to the M.
Someone needs to jump on this....coated too!
GLWS
      07-19-2014, 08:53 AM   #3
bjbstewart
bjbstewart's Avatar
GLWS
Agreed! Have you put a tune on it too?
[SIGPIC][/SIGPIC]
      07-19-2014, 10:17 AM   #4
fullerra
fullerra's Avatar
14
test test  [0.00]
I did,
At the time of the install, I had an ESS tune in place, There was no dyno performed afterward, but the butt dyno felt much more impressive after this, than with just the tune alone.
Since then, had evolve tune, and now possibly epic tune.
      07-20-2014, 03:59 PM   #5
The Shoe
The Shoe's Avatar
27
Drives: 2007 Z4 M COUPE
Will you take 875.00? Can do quick paypal
      07-21-2014, 09:24 AM   #6
bjbstewart
bjbstewart's Avatar
These are sold - thanks all for the interest!
[SIGPIC][/SIGPIC]
Tags
fabspeed, headers, s54
