      08-24-2015, 04:24 PM   #1
Z4M_LEV
Drives: Z4M, 750i, F30, Q50S, VW
Installed 19" M3/M4 wheels on Z4M!
So I've went through half a dozen sets of wheels and tires to come to a final decision on which to keep and which works well. I came to conclusion and installed new M3/M4 19" wheels (black) with Michelin PSS. 255/35R19x9 ET29 (Front) 275/35R19x10 ET40 (Rear). I only had rubbing issues in the back cause of my chamber degree, but a 10mm spacer solved it! Will post more pics on demand!
Sorry if the picture quality is bad, always have an issue uploading with my phone. Cheers!
      08-24-2015, 04:32 PM   #2
Gregoryse
Malta
Drives: wiesmannGT5
Looks great man, good job.
      08-24-2015, 04:55 PM   #3
Z4M_LEV
Thanks!!
      08-24-2015, 11:27 PM   #4
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Ditto. What are the wheel specs? Thanks.
      08-25-2015, 01:16 AM   #5
Z4M_LEV
19x9 front, 19x10 rear. offset ET24 Front & Rear.
      08-25-2015, 08:48 AM   #6
mcoupe5/6
mcoupe5/6's Avatar
Drives: 08 M Coupe
nice! those rims give it a more modern look for sure.
      08-25-2015, 09:44 AM   #7
Digs
Australia
133
Drives: Z4M Coupe
Very nice! Keep the original flavour but with a modern twist.
More pics please, if possible.
      08-25-2015, 10:03 AM   #8
3002 tii
3002 tii's Avatar
2286
Yellow calipers are nice touch as well...
Follow for latest mods
      08-25-2015, 01:34 PM   #9
Z4M_LEV
Appreciate it, more pics will do!
      08-25-2015, 02:00 PM   #10
Beedub
im guessing those will rub massively when driven hard... + 24 upfront isn't really viable on this car!
      08-25-2015, 02:19 PM   #11
Z4M_LEV
No rubbing AT ALL actually, I have +22 prior to this and still zero issues. Only rubbed with my 275 square setup, after switching to 255, it's been perfect.
      08-25-2015, 03:19 PM   #12
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Did you have to roll any fenders? What's your front/rear camber settings?
      08-25-2015, 04:08 PM   #13
Z4M_LEV
Did not roll fenders, front is 2.3° rear is 1.8°
      08-26-2015, 01:36 AM   #14
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Very interesting to hear that 275/35R19x10 ET24 is rubbing on the inside edge with near stock camber settings. I would have expected the front 255/35R19x9 ET24 to rub on the outside fender
      08-26-2015, 01:40 AM   #15
Z4M_LEV
Yea front is perfect, no spacers or anything needed either.
      08-26-2015, 06:41 AM   #16
Beedub
according to bmws own literature the front is ET29.... rear ET 34 ( makes sense since you added 10mm spacer) so you either are mistaken or you have reps.
      08-26-2015, 12:18 PM   #17
Z4M_LEV
Might be mistaken, cause they're 100% original bought them from the dealership and the invoice said ET24 F&R. Idk why.
      08-26-2015, 12:44 PM   #18
Shorts
Drives: E86 M coupe, E91 325xi
Looks great, please post more pics
      08-26-2015, 02:35 PM   #19
Z4M_LEV
Just did some research, says front is ET29 and rear ET40
      08-26-2015, 02:36 PM   #20
Z4M_LEV
Apparently I was given wrong info on the offset, it's not ET24 squared. It's ET29 front ET40 rear.
      08-27-2015, 11:36 AM   #21
Beedub
more detail pics needed with better cam please!! car looks awesome!
      08-27-2015, 03:13 PM   #22
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
Love the look. Nice job
instagram: @ dubsesd
