08-17-2017, 07:48 PM | #23 |
Rep 2,866
That was also my plan on the next replacement
11-28-2017, 04:03 PM | #24 |
Rocket Scientist
Rep 72
Drives: '08 M Roadster
I've pushed my 2008 original battery far enough and need to swap it out. Just to confirm, the ///M uses an AGM battery, not flooded, correct? If I replace it with a like-AGM I shouldn't have to reset the battery management software, correct?
thanks!
2008 ///M Roadster
11-28-2017, 04:22 PM | #25 |
636
Rep 3,124
I think some have used flooded to save money, but I would stick with the AGM since it's essentially in the passenger compartment with you.
H6 is the factory size. There's no battery management software. Just pop a new one in and go. Not Rocket Science Make sure to remove and save the little elbow that connects the vent hose. The new one won't come with it.
11-28-2017, 04:27 PM | #26 | |
Rocket Scientist
Rep 72
2008 ///M Roadster
12-05-2017, 07:12 PM | #27 |
Rocket Scientist
Rep 72
Installed Napa's 9848 battery in my ///M this past weekend. Exact size of the BMW original battery that came out. Was surprised by how much corrosion was on both battery clamps, spent a good hour (went slow with lots of absorbent pads down to collect all the drips) scrubbing them with a baking soda paste and then coated them with dielectric grease. Old battery measured 11.9 volts when I pulled it out of the car. New battery measured 12.8 v. It was well past time to swap it out...
2008 ///M Roadster
