08-01-2017, 08:54 PM | #1 |
///Multiple
2992
Rep 4,243
I went to drive my Roadster today. Not my primary car anymore, it sits in the driveway with a cover on it, hooked up to a CTEK battery charger. I took off the cover and then opened the hood to disconnect the charger. Found a live bunny sitting on the middle of the engine. Not sure who was more startled. Then I discovered that he apparently had made a lunch of a cable that probably has something to do with the fuel electronics. You can see where he chewed the entire cable and just left little nibs on the connectors. You can even see where he left some of his fur. Damn you wabbit!
My laptop is down and I'm using my tablet, making research more difficult. Anyone know what cable this is, the p/n, and how much it costs? https://goo.gl/photos/LqkZemVQi2t3ZdEm8
08-01-2017, 08:56 PM | #2 |
///Multiple
2992
Rep 4,243
Crap, can't even post a photo using the mobile app.
08-01-2017, 10:22 PM | #3 |
Rep 202
Sorry to hear that.
The first Z4 that I went to test drive when I was on the hunt (2003 2.5i), I popped the hood and there was a rather large bunny sitting on top of the engine. It didn't look like it had chewed on anything so I was able to test drive it. I certainly would not have bought it without a very good PPI to check for chewed wiring as a rabbit had chewed on the wiring of my wife's Jetta and we did have to replace a couple of wiring harnesses. In the end, I bought a different Z4 (2006 ///M). There are some ultrasonic devices that are marketed for autos as a rodent repellent that you might want to check out.
2006 Z4 ///M, Interlagos Blue/Beige
08-01-2017, 10:27 PM | #4 |
Rep 202
You can try checking http://realoem.com for that wiring harness.
08-02-2017, 10:42 AM | #6 |
636
Rep 3,124
I think that's the crank case vent.
08-03-2017, 12:39 AM | #8 |
636
Rep 3,124
Maybe cut a pigtail off a donor. It's probably part of the main harness and not sold separately.
If it were me I'd: 1) Grab an Xacto knife 2) A Band-Aid (be careful!) 3) Some 24 AWG wire 4) A soldering iron 5) Some burn cream (dammit!) 6) Some heat shrink 7) More burn cream (seriously?!) 8) Cut the outers back far enough to strike good wire and patch in a section. 9) Cover it all with some 1/4" corrugated loom. No one will ever know. 10) Get some rabbit fence to put around the car.
08-04-2017, 08:39 PM | #10 |
Rep 18,727
Call your insurance company. It's covered under your comprehensive insurance, less deductible. And no, they won't increase your premium.
08-18-2017, 04:35 PM | #11 |
///Multiple
2992
Rep 4,243
I ended up taking the car to my independent mechanic. He spliced in a new section between the plug and rest of the cable, the part that had been chewed off, soldered it, wrapped it with electrical tape and then put heat shrink tubing on it. That fixed that problem but the airbag light was on. I discovered two other cable housings that had chew marks on them but no damage to the wires inside, so I wrapped those with electrical tape. Took it back to my mechanic and he found that a wire to the airbag sensor, not readily visible, had been chewed so he fixed that.
The only remaining problem, and this is the problem that started a few months ago. The radio will cut out and the car tries to make an SOS call. BMW Assist has long been expired and my current phone was never paired to the car, so it eventually tmies out and the radio will play for a short time, then the whole process starts all over again. According to the codes that my mechanic pulled, the SOS switch is bad, although he's not sure that will fix the problem, as it can also be tied to the Bluetooth module. He's pretty sure that this is not related to the chewed cables because of the codes. Anyone replaced their SOS switch? How difficult was it? In the middle of all this, my wife had to stop her 335is on the freeway when she got an error message on the nav screen telling that the car had overheated and to pull over immediately. She had told me that the cooling fan was surging, coming on high, then back to normal, I rode with her and agreed that something was not right, so we made an appointment at the dealer later that week, because we have an extended warranty on her car. The night before the appointment, on her way home, is when she had to pull over. We had it flat-bedded to the dealer. They replaced the water pump and also discovered that there was oil leaking from the oil filter housing, so they also fixed that. All covered by the warranty with $50 deductible. Three BMWs and two of them were in the shop the same week!
08-18-2017, 07:38 PM | #13 | |
///Multiple
2992
Rep 4,243
Thanks for the link. I've ordered the oddments tray from ECS Tuning. That's a great replacement for the now-useless buttons.
