      07-30-2017, 04:40 AM   #1
acer54
Drives: Z4
Alarm System
It would appear that my Zed does not have an alarm system, I have checked under the hood/bonnet for a microswitch at the V of the cross brace and there is not one present, I then checked to see if the car is pre wired for an alarm and the wiring does not appear to be present either.
I was under the impression that Zeds came pre wired so the alarm system can be retrofitted, can anyone advise if in fact they are pre wired or not?
If they are not then probably the most cost effective way is to fit an aftermarket system but that will probably mean another fob which I would like to avoid if at all possible.
      07-30-2017, 07:00 AM   #2
JCF
Drives: 07 Z4 M Coupe
They are pre-wired. The wiring harness is tucked over by the brake cylinder.
http://www.bimmerfest.com/forums/sho...53&postcount=9
/// LED Lighting /// Pedal Haus M aluminum pedals and heel plate /// BMW logo puddle lights /// CF wrapped console /// LeatherZ MK4 console storage, armrests, door pulls /// ZHP illuminated shift knob /// BMW under seat storage /// Soundplicity III /// Stubby Antenna /// Eventuri Intake /// Tekcarbon CF valve cover /// Stromung exhaust /// Rogue Engineering Transmission Mounts ///3rd brake light blinker
      07-30-2017, 03:13 PM   #3
acer54
Drives: Z4
I just cannot find the wiring for the hood/bonnet switch near the brake servo that's why I was wondering if it was pre wired.
      07-31-2017, 02:01 AM   #4
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
The photos on this thread may help: https://www.bimmerforums.com/forum/s...lation-for-E86
2006 Z4 ///M, Interlagos Blue/Beige
2006 Z4M Interlagos Blue/Beige
      07-31-2017, 05:19 AM   #5
acer54
Drives: Z4
Excellent tutorial and photo's but I still cannot find the wiring, mine is right hand drive so brake servo is on the other side of the firewall but I do not think that will make a difference with the wiring loom.
Update
Checked my VIN and option S5GAA (Alarm Prep Pack) is not listed which explains why I cannot find any wiring.....
It looks like I'm limited to fitting a 3rd party alarm system without immobilizer.
