06-03-2014, 10:38 PM | #1 |
Rep 86
Drives: 3.0si Coupe
STR Wheel fitment on NonM
Can anyone confirm these will fit a 07 si coupe with sport. Coming from 203s. Stock suspension as far as I'm aware.
STR 607 front 18x8 et35 rear 18x9 et40 Last edited by jmilt13; 06-03-2014 at 10:44 PM.. |
06-03-2014, 11:57 PM | #2 |
Retrograde
18
Rep 390
Those should fit no problem. You could get away with 10mm spacers on each depending on the tire/fitment you want. But with stock suspension and normal sized tires there should be no issues.
06-04-2014, 01:57 PM | #3 |
Rep 86
Drives: 3.0si Coupe
Cool, my best guess was that the fronts would stick out about 0.4" more than normal and the rears about 0.7" more than normal. Which might look better actually.
Thanks! |
06-05-2014, 10:20 AM | #5 |
Rep 12,565
I read this the same way but I don't think OP is referring to Street Touring Class (STR) rather the wheel brand STR (see center cap in picture).
