      02-24-2012, 08:54 PM   #23
Jax543210
Jax543210's Avatar
Drives: 2007 Z4 Coupe
Originally Posted by bucko521 View Post
Ok, I can't make heads or tails out of this thread.
If I want to get my trunk to pop up more...which of the two part numbers should I use?
P/N 51248137994 are the 23N*
P/N 51248187291 are the 34N*
I went to my local dealer to view each part.... seems they need to special order these for me to even view which ones I should get. I even explained exactly what I was trying to accomplish to the parts guy.
The guy said he had no idea...he could order the parts based on the numbers I gave him but couldn't promise I'd actually get what I wanted cause it wasn't verified by a BMW Tech. And to top it off, he wanted an up front cost for the special order with $25.00 shipping charge....and a 50% re-stocking fee IF I don't want to keep either set.
Sheesh...I sure wish I had a decent stealer to chat/deal with.
In the end...I'll order online and not give these guys one Canadian nickel.
Our dealers/service/parts etc down here are just as helpful..errr..helpless.
ECS has pics on their site of these ejectors.
http://www.ecstuning.com/ES92255/
http://www.ecstuning.com/BMW-E36-323..._2.5l/ES92303/
      02-24-2012, 09:21 PM   #24
bucko521
More of this than that!
bucko521's Avatar
Drives: BMW Z4 3.0i, Z3 2.5i
Thanks for the pictures...however....it still shows me two different parts numbers. From the pictures...they look identical. The original thread photos show them different in size.
What I want answered is which one do I buy to allow for the truck to pop more. I'd buy two of each and just take a gamble...but someone must be able to let me know what ones NOT to buy.
Is it:
or
'06 Z4 3.0i Jet Black/ Biege/Black
Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill
Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector
      02-25-2012, 01:12 AM   #25
Ron Stygar
Drives: 2006 Z4 M Coupe
My Z4 coupe 2007, did not come with ejector buffer stops for the hood. The stops under the hood are weird and have a phillips head screw in the center of them. How do I remove this type of stop and can it be replaced with ejector style buffer stops?
http://www.bimmerfest.com/forums/sho...4&postcount=59
      02-25-2012, 01:29 AM   #26
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
The length (height) of both are the same. The 34N* is the more "powerful" of the two if you want more "pop", due to the stiffer spring rate used. Note that the 34N* may be more prone to breakage due to the stiffer spring rate. If it breaks, the end cap and spring may end up rattling inside your trunk's sheet metal...one of the reason I decided not to do this mod after seeing how my front ejector failed (an engineer's pessimist point of view )
Is it:
or
      02-25-2012, 11:03 AM   #27
Ron Stygar
23 Nm and 34 Nm
http://www.onlineconversion.com/torque.htm
23Nm = 16.96 pound foot
34Nm = 25.08 pound foot
To lift the Z4 M coupe lid is 11 pounds.
Two 23Nm works with my car.
      02-25-2012, 03:38 PM   #28
Jax543210
Jax543210's Avatar
Originally Posted by Ron Stygar View Post
thanks Ron, the second I tried to turn the screw on top of the ejector...plop...the whole ejector fell through the bottom of the buffer stop into the inside of the bumper. I got the ejector out through the fog light access panel in the wheel well. It was hollow, no spring in sight. The spring must have fallen out the bottom of the ejector a long time ago.
I tried to adjust the gap on the Coupe's hatch when it closes by turning the stops in the rear but they are both (left and right side) bottomed out as far as they will go. Perhaps if I pull them out and dremel more grooves/thread into the stop so I can spin it down further? The top stop ( the stop on the hatch itself) looks like it is not adjustable; just a solid piece of rubber material.
      02-25-2012, 08:40 PM   #29
Ron Stygar
Look at the first pic in number 1.
      02-26-2012, 12:15 AM   #30
bucko521
bucko521's Avatar
Ron, as always you come up with answer.
Question....would not the coupe lid be much heavier than the roadster trunk lid? Or am I missing something?
      02-26-2012, 12:17 AM   #31
bucko521
bucko521's Avatar
Excellent....I will check and see if I can source a set from another Canadian BMW dealer.
      02-26-2012, 07:44 AM   #32
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by Finnegan View Post
Don't slam the hood at all, and they've failed on one of our cars. They're just sitting there just below the top, not yet pushed through. But the spring has sprung! (Happened over the holidays.)
Guess I need two lower strength ones. Perfect timing on this thread!
Had the same thing happen on my Z4MR.
So far, so good on the coupe.
good info on the different spring ratings in here.
      02-26-2012, 07:45 AM   #33
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Tried this mod today, but unfortunately, it didn't work too well for the coupe...probably due to the hatch being heavier than the roadster. .................
At least with the coupe we have the Roundel to use as a handle.
      02-26-2012, 09:03 AM   #34
Ron Stygar
M roadster trunk lid:
20.13 lb $850.90 retail
http://www.penskeparts.com/DiagramsR...iagram=41_1455
M coupe trunk lid:
31.31 lb $1,131.71 retail
http://www.penskeparts.com/DiagramsR...iagram=41_1696
      02-26-2012, 09:43 AM   #35
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
M coupe trunk lid:
The Z4M has a special trunk/hatch?
Also I don't think the weight listed for the Coupe hatch includes the glass.
      02-26-2012, 10:14 AM   #36
Ron Stygar
Correct. I did the trunk lids.
Glass is 16.57 lb $400.15 retail
I lifted my coupe lid at 11 lb.
I don't have a roadster to do the lift.
Maybe someone will.
