04-16-2024, 08:29 AM | #1 |
Rep 35
So I’ve been struggling to diagnose a problem with the m54 that is in my z for a few months, and I’ve finally given up trying to fix it. It runs well when it’s warm outside, so my plan is to build up a new engine to swap into it this fall, but I’m unsure which one would be best. Ideally id like to find motor mounts and brackets and such that I can purchase online rather than designing them myself (although it seems it might come to that at this point in time), so does anyone know if there are kits out there for swapping it to a v8? Id also like to say I’m not looking for recommendations of selling the car and buying a new one, practicality isn’t necessarily the goal of this project, it’s more about getting the hands on experience for me.
04-16-2024, 09:10 AM | #2 |
Rep 2,705
Never looked into an engine swap, but my first thoughts would be the computers compatibility.
Anything is possible if you throw enough money at it. Having said that, there is well documented 2JZ swap on this forum.
04-16-2024, 10:59 AM | #3 |
Rep 685
If you can't figure out the issue with your car I wouldn't recommend an engine swap, that's going to be infinitely times harder and require a lot of trouble shooting. I would stick it out with what you already have. The M54 is very simple to work on and reliable.
04-16-2024, 11:02 AM | #4 |
Rep 35
The problem I’m having is making it unreliable lol. I’ve had it to almost a dozen different shops and none of them have any idea what’s wrong, other than the engine just doesn’t run in cold weather
04-16-2024, 11:15 AM | #5 |
Rep 4,058
Aloyouis210.00 Murf the Surf19103.50 |
04-16-2024, 12:21 PM | #6 |
Rep 685
Have you done a cold cylinder pressure check? Just curious. I'm betting it's something electrical, that'd be my guess. I always tell everyone to replace your MAF connector, not the MAF itself but the actual male plug. Also never use an aftermarket MAF sensor. My car drove me nuts with codes, poor cold starts and idle (to the point you couldn't trust it) and hesitation. Saw someone on the UK forum complaining about the same thing and said it was the plug. After 2 years of my struggles I tried it ($25 kit from ECS Tuning) and my problem has been fixed for over a year. No one was able to figure my issue out either. Worth a shot if you haven't done it. It basically just shows up as erratic behavior on any diag computer so techs can't figure it out and also the cars computer can't figure out what's going on either.
04-16-2024, 12:25 PM | #7 | |
Rep 35
04-16-2024, 12:35 PM | #8 | |
Rep 685
https://www.fcpeuro.com/products/bmw...-12527512935kt |
04-16-2024, 12:44 PM | #9 | |
Rep 35
04-16-2024, 12:49 PM | #10 |
Rep 685
Excellent! Just make sure to take your time, the metal pin/wire holders are a little tricky but the whole thing should only take 30mins tops. It's critical that you get everything fully seated and tight, any looseness in the wires going to the pins and you'll have the same issue. They basically come loose over the years from vibration.
04-22-2024, 06:49 AM | #13 |
Rep 18,769
04-22-2024, 08:08 AM | #14 |
Rep 35
04-22-2024, 10:34 AM | #15 |
10951
Rep 4,908
IF it was the connector, that would be very very easy to diagnose.
I assume you've read out live data during the non starting issue? If it's the MAF connector, you'd either see the L/S airflow or the IAT being way off. Swapping out the engine to a completely different engine that was not featured on the platform because of running problems with the original engine sounds like a useless undertaking. The easiest thing to do on cars is keep the original packeage running. Even swapping out the engine for another one of the same model and make is more difficult if it's a used one...you never know what you're gonna get. Go to a competent mechanic. From what I've read in your particular situation, it's only been a parts cannon deal, not a diagnosing deal.
pungo886.00 |
04-23-2024, 06:28 AM | #17 |
Rep 35
Quick little update: it was 38F out this morning, before starting the car up I took some pictures through the spark plug holes. When I started it up it started surging for a few seconds, then shut off with a loud bang and the check engine light came on flashing…
04-23-2024, 07:55 AM | #18 |
Rep 2,551
wigwig Hold on, weren't you the one that was having all kind of trouble trying to bolt the camshaft back down and now you want to tackle an engine swap with a completely different model engine like a V8
04-23-2024, 07:56 AM | #19 |
Rep 35
04-23-2024, 08:51 AM | #20 |
dances with roads
4738
Rep 4,099
Oh, so THAT's why you assume it's the engine!
