      11-18-2010, 02:15 PM   #1
drt111
Drives: BMW Z4 2.5si
Z4 2.5si wheel offset
Dear all,
I am new to the post. Apologies if this question may sound stupid.
I would like to install 18" rims and was wondering about the correct offset.
Was looking at advansa rims and the offsets given are the following:
18"x8.5" +38mm
18"x8.5" +32mm
18"x9.0" +24mm
18"x9.5" +35mm
18"x9.5" +25mm
18"x10.0" +20mm
these are fairly different from the standard z4 setup
could you please indicate which could be the perfect offset to install so that performance is not affected?
would really appreciate your help.
thanks alot
      11-18-2010, 04:13 PM   #2
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
I would recommend the following for your 2.5si:
18"x8.5" +38mm
18"x9.5" +35mm
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover...
      11-19-2010, 03:09 AM   #3
drt111
thanks alot... will there be any major difference in performance from the standard offset which is;
Standard wheel size/offset for a non-M is: front 18x8.0 ET47, rear 18x8.5 ET50
thanks for your advise
      11-19-2010, 10:26 AM   #4
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
18"x8.5" +38mm
18"x9.5" +35mm
i would not recommend 18" x 9.5" et35 for the rear...
see this post - http://www.zpost.com/forums/showthread.php?t=344535
9.5" et35 will stick out 2mm farther than the 9" et30 used in the above post.
      11-19-2010, 12:03 PM   #5
vortex_tuning
Drives: E92 M3
9.5" ET35 will stick out a little bit on a non-M. You will need to add some negative camber to tuck them in. I'd recommend 9.5" ET40-45.
      11-19-2010, 06:35 PM   #6
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
That's interesting...I ran a set of 19X10s et35 for the rear with 265/30/19s and it didn't stickout as it did for the above post. My car however is lowered, with a good amount of negative camber, so that may be why .
      11-20-2010, 03:45 AM   #7
drt111
ok... so the best set up would be:
18"x8.5" +38mm
18"x9.5" +40-45mm
thanks alot for your help...
I have also seen a set of ultraleggera's. They come 18"x8 front and 18"x9 rear. What would be the ideal offset??
Thanks alot for your help guys...
      11-20-2010, 03:42 PM   #8
v3.0si
v3.0si's Avatar
front -->
9.0" width = et42 (might be close to the suspension)
8.5" width = et35
8.0" width = et29
rear -->
9.5" width = et42
9.0" width = et35
8.5" width = et29
there is essentially a 0.5" difference between the front and rear widths vs. offsets for the non-///m cars. IMO, the best look for the non-///m's is...
18" x 8.5" et40 front
18" x 9.5" et45 rear
you can use an 8.5" et35 in front, but it is really flush. you may find that a minor increase of front neg camber gives a less aggressive look with this offset. but in the end... it's all about personal taste.
also, IMHO a 19" dia makes the non-///m brakes look silly and small. especially in the rear. definately search the forum for pics before you buy anything. the main "color thread", which has lots of pics, can be found here...
http://www.bimmerpost.com/color-threads/
...otherwise use the search function.
      11-21-2010, 09:08 AM   #9
dharper
BMW CCA Member
dharper's Avatar
Drives: '19 BMW X3 30i-'11 BMW 128i
The new wheels I just had installed on my '03 2.5i Sport pkg. are 18x8 with 35 offset in front and 18x9 with 38 offset in the rear. They fit flush with the wheel wells/fenders.
Pretty much what others have recommended for the 2.5i as well. They're just about as perfect a fit that you're gonna find.
      11-21-2010, 07:11 PM   #10
v3.0si
v3.0si's Avatar
^ Avant Garde, correct? Looks great!
      11-23-2010, 06:05 AM   #11
dharper
BMW CCA Member
dharper's Avatar
You are correct, sir.
And thank you.
      11-23-2010, 01:59 PM   #12
drt111
I was going either for the Forgestar F14 or the Advan RS
Forgestar is no problem for offset however I still need to get a reply from Mod Bargains. Advan RS they only come with +32 front and +35 rear this is according to the guy at European Auto Source.
But the Forgestars are a little bit expensive
