10-03-2010, 08:24 PM | #1 |
M52, M62TU, S50US, S54, S65
75
Rep 569
Volk TE37 18x9 et40 squared setup got Z4MC
Hello Z4 enthusiasts!
I am about to land on a deal this following week for an M Coupe and I was wondering what size of tires should I run with the squared setup. I want to run same size tires all around so I can rotate the tires. I will also be running a coilover setup, so any suggestion on coilovers are also welcome!
1995 E36 M3 USA / 2002 E46 M3 SMG / 2008 E90 M3 6MT 1996 E36 328i Touring 5MT / 1998 E36 323Ti M Sport 5MT 2002 E39 540i Protection |
10-03-2010, 09:38 PM | #2 |
Rep 1,855
245 mm is about the largest you can get in the front.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
10-04-2010, 10:28 AM | #3 |
Rep 12,565
can you not run a 255/35 or is a 35 profile too short?
10-04-2010, 11:00 AM | #4 |
75
Rep 569
I wanted to run 265/35 but I'd probably have to go -2.5 degree camber up front... Anyone running 265 up front?
10-04-2010, 01:32 PM | #5 |
Rep 1,135
a long time ago i saw a set of 265's for sale that were used in the front... i would imagine though that you'd have to run more than 3 degrees of negative camber.
10-04-2010, 02:16 PM | #6 |
Rep 232
I run a squared setup that size for track, but I definitely wouldn't recommend it for street. As dorifto88 mentioned, you need like 3.3 degrees of camber in the front.
10-04-2010, 06:01 PM | #7 |
Rep 1,135
a square setup would be nice from an economic standpoint (i mean, when you pay for nice tires you want them to last as long as physically possible) but when i had 265's on all 4 corners of my g35, you can really feel the tire width at the wheel... steering in general becomes a lot heavier... i was planning on a square setup too but considering the stock (rear) tire dimensions to a 265/35 tire, i think i'd rather get 265 front 275 rear (if i wanted that much tire... which i dont lol
10-04-2010, 11:02 PM | #8 |
75
Rep 569
At first, I was planning to keep the TE37s for track use only and get my hands on another set of wheels. For the TE37s, I'm planning on going squared fitment and make the 265s fit, which fits perfectly on my M3.
But then again, I'd rather have a staggered set of wheels for daily driving, and that, I'm still undecided for which set should I go for. I'm not sure if I can go 19x10 with +25 offset on the rear... I want to make it have an aggressive fitment set of wheels, but not to the point where rubber meets fender. Inputs + opinions would be great!
10-11-2010, 10:55 PM | #9 | |
DHS
204
Rep 4,013
I am also running a 19.8.5 +35 front with 245/35/19 tire. Of course the OEMs feel much better on the road but black on black looks sweet. I do switch back and forth from my 18 inch OEM E46 M3 wheels and Volks on my Z4.
2023 BMW M4 2016 X3 Last edited by Endless619; 10-11-2010 at 11:10 PM.. |
10-12-2010, 07:50 AM | #10 |
Rep 9
You can make it work with those dimensions (4 x 9" / 18" / +40mm). I have the exactly same setup on my Z4MC with some OZ Ultraleggera's. Not sure if it works with a stock suspension, but at least with some coilover sport suspensions it does. I added a KW Clubsport to my car, went with -2.0 degrees camber at the rear and -3.3 at the front, lowered the car and it works great. No rubbing. No body work on the fenders needed. Spacers needed (15mm front, 20mm rear)
Tires: I fitted Toyo R888 Trackday tires 255 x 35 / 18" squared, which have a very wide tire tread of around 268mm (measured). In fact they conform to tires with 265mm width. With all that, your car will feel completely new. It goes around corners at unbelievably high speeds (of course, with those R888's). But the best thing is the neutrality - understeer is totally eliminated! Exactly what I wanted. (Sorry for my bad english - I'm Swiss) Last edited by czsimo; 10-12-2010 at 09:31 AM.. |
10-23-2010, 05:42 PM | #11 |
DHS
204
Rep 4,013
Pics!
2023 BMW M4 2016 X3 |
10-25-2010, 10:43 AM | #12 |
75
Rep 569
you found them on e46f! same exact set that was with kaiv. I traded one on one with a set of BBS CH.
10-26-2010, 09:00 PM | #14 |
Rep 1,349
I ran 18x9 ET33 with 255/40/18 tires up front for a while, the car was on stock suspension at the time. The tires came really close to rubbing the struts inside with about 1mm space.
18x9 ET40 may not clear the struts, you will probably need spacers for the front. |
10-27-2010, 03:15 AM | #15 |
Rep 9
10-27-2010, 01:49 PM | #16 |
75
Rep 569
HMMMM... I'm running it right now with 255/35 and everything seems to be fine
10-27-2010, 02:18 PM | #17 |
Rep 1,349
