01-13-2016, 11:40 AM | #1 |
Rep 2,782
FS: 03-05 catted track pipe
$120 plus shipping. O2 sensors not included. Up for sale is my catted track pipe for the 2003-2005 Z4 with M54 engine. It is not OBD2 compliant (meaning you will get a CEL without a tune). The cats reduce the noxious fumes that result from deleting the OEM cats in the headers, but without a noticeable impact to performance. Catless headers + this s-pipe will yield about a 12-15 horsepower gain on a stock car, and significantly more on a car with forced induction. Sound-wise, the tiny cats don't make a big difference. All the burbles and pops of a catless setup are there. Fumes are reduced by 80%, so the car will sound catless but won't smell like it... which is a good thing if you don't want to risk a four digit ticket for running catless on the street. The s-pipe has dual Magnaflow cats, P/N 50004, with 10-15k miles on the cats. It has two O2 sensor bungs, which can be used as placeholders (if you get a tune that's OBD2 ready, it still requires O2 sensors to be properly connected). I have $500 in parts/labor plus my stock resonated s-pipe in this setup. Magnaflow P/N 50004 Product Info
01-23-2016, 10:44 AM | #2 |
Rep 2,782
Bump. I'll be taking this by the recycler soon to get it out of the garage.
01-23-2016, 06:18 PM | #3 |
Rep 12,565
Surprising the cats don't do enough to keep it emissions compliant. Have you tried O2 spacers? I might have a spare set you can try if they work.
01-24-2016, 08:21 PM | #4 |
Rep 2,782
Thanks for the offer. I didn't try spacers or a tune... I ended up buying a Supersprint s-pipe since it's slightly larger in diameter to support more flow.
The cats probably aren't too far off from passing emissions, since they are 400 cell and pretty far upstream.
