06-22-2012, 10:52 AM | #23 | |
Rep 1,135
06-24-2012, 08:54 PM | #24 |
Rep 2,120
Looks awesome Dan!
Next time your up my way swing round so I can see it in person, What you doing with your stock drivers seat? lol
Imola Red Roadster |
06-24-2012, 09:21 PM | #25 | |
Rep 12,565
sitting in the garage for now lol |
06-25-2012, 12:05 AM | #26 |
Rep 2,120
If you ever need to clear space hit me up
Have a non car related idea
06-27-2012, 11:30 AM | #27 |
Rep 606
I just pulled the trigger on getting the new foam seat with the sensor. I'll report back on how this turns out...
06-27-2012, 11:53 AM | #28 |
Rep 1,135
i wish you the best of luck. remember to disconnect the battery and to not plug it back in until your seat is fully installed and plugged in, otherwise you will have to reset the airbag light
06-27-2012, 12:20 PM | #29 |
Rep 505
07-13-2012, 02:36 PM | #31 |
Rep 12,565
Bump for update
12-16-2012, 03:55 AM | #32 |
Rep 5,328
Sorry to bump this...
DSC does the seat foul the door card at the top???? any info would be great :-) ive just sourced a second hand pear that i simply culdnt refuse :-) any tips, further info on this path im about to take would be REALLY appreciated!! im going to use the stock seat belts, is this going to be an issue, i.e to they still sit nicely on your upper / lower body ;-)
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 12-16-2012 at 06:34 AM.. |
12-16-2012, 11:47 AM | #33 | |
Rep 12,565
Stock seat belts work fine but because the lap belt will go over the seat, it's not very tight. I didn't feel safe on track like that so I purchased a seat belt extender, snaked it through the side hole, and clipped that way. Now it's tight and snug. Everytime I get in, I just have to lift my right butt cheek to get the belt clip around my body and then clip in lol. See below |
12-16-2012, 11:50 AM | #34 |
Rep 12,565
Beedub - one other advise, before you bother even bolting the hardware into the floor or onto the seats, first line up the hardware with each other (floor mount to slider, slider to receptacle spacer, receptacle to side mount) and check to see if all the holes line up. If they don't, drill / bore those out first as its much easier to do that way than find out after its too late and everything is bolted on.
12-16-2012, 01:19 PM | #35 |
Rep 5,328
DSC that info was invaluable!!!!! thankyou very much bro!! great info on the buckel, i had a feeling you wouldnt feel "safe" by the looseness of it all.
in your opinion would a narrower seat be ideal??? i see recaro do the APEX and the furious, which is basically a narrow body PP.
12-16-2012, 02:31 PM | #36 | |
Rep 12,565
I find the Recaro PP to be perfect for my build. I'm 5'9", 38 chest and 165lbs. My torso is slightly on the bigger side so I find the shoulder area to be a little on the narrower side but aside from that it's fine. Last edited by 3002 tii; 12-17-2012 at 04:03 PM.. |
12-17-2012, 04:07 PM | #37 | |
Rep 12,565
By angling the front of the seat higher, it forces your butt to sit further back and takes the stress off the lumbar area (your lower back is fully flush with the seat and is better supported). Not to mention you're a little more secure under braking. If there's 4 slots on the front of the side mount, I put the front on 2nd highest and rear at the lowest. Ironically you also gain a little headroom this way because the roof curves down towards the windshield. This new seating position puts your head a little further back. Since switching my seat to this position, I did 4 additional track days and not a single day of back pain, it's 10x more comfortable. |
12-17-2012, 05:23 PM | #39 |
Rep 12,565
I love it but I think it matches my dream red interior better than imola, which is slightly darker.
