      08-19-2009, 09:27 PM   #1
fatmatt0116
Hooligan
fatmatt0116's Avatar
Drives: 2014 Porsche Cayenne Turbo S
chirping the tires
Is it easier to chirp the tires when they are new?
2011 X5 5.0 Dinan - SOLD
2007 Imola Red Z4 M Coupe -SOLD
2004 Navy Blue BMW 325Ci
      08-19-2009, 10:23 PM   #2
VitaminT
Drives: 2006 M Roadster
New as in 0 miles? New tires sometimes tend to be a bit slippery depending on how much mold release goo is left on them. This shoudl wear away by no more than 500 miles. After that some tires have a uniform tread compound and some have a sticky outter layer and a harder more wear resistant inner layer.
      08-19-2009, 10:27 PM   #3
fatmatt0116
Hooligan
I seemed to be able to chirp the tired more easily when the car was new. I'm still on the factory conti shits though they now have 10 k on them
      09-13-2009, 11:43 AM   #4
Car_Girl
Car_Girl's Avatar
Drives: 2013 BMW X5 xDrive 5.0i
It would seem that chirping the tires isn't necessarily a matter of tire age but more so a matter of traction - the higher the frictional force between the tire treads and the road surface, the more likely you'd be able to chirp the tires during a rapid shift. Think back to the days where you had rubber bottom gym shoes on a shiny gym floor surface and just about every step you'd take would cause a chirping noise. Now imagine those same shoes with dust on the bottom across a dusty floor surface - not nearly as likely to chirp so I'd say the same idea applies to tires.
Of course VitaminT makes a good point - when the tires are brand spankin' new, they've got an ejection mold compound on the surface that takes time to wear off - that's the tire goo of reference. It's a bit oily to the touch.
      10-06-2009, 11:51 AM   #5
The HACK
The HACK's Avatar
1821
Originally Posted by shift@red View Post
the two above posts are correct. and that 'goo' is called cosmoline.
They use cosmoline for mold release?
