      03-17-2016, 06:14 PM   #1
No_Dominion
No_Dominion's Avatar
117
Drives: 2007 Z4M Coupe
First Dyno Run (With Mods)
I have some time slotted for my first ever dyno run tomorrow at RPM Performance here in Indianapolis. I'm looking forward to seeing what the combination of intake/headers/tune end up yielding. I know what my butt dyno says, but verifiable numbers are always nice, haha.
I'll be sure to update this post with dyno plots as soon as I'm able to tomorrow.
UPDATE
Just got back from RPM Performance after my dyno runs, and I'm definitely pleased with the results. For some background info, they use a Land & Sea dyno, running the latest Dyno-Max Pro 2010 software. As one of the premier performance shops in Indianapolis, they need their dyno readings to be realistic, and not exaggerated, so the readings they give are as close to accurate as they can possibly get them.
Temperature during runs was 60 degrees in the dyno bay.
Mods on the car:
Eventuri CF Intake
Status Gruppe Headers
Evolve Tune
Results:
RPM/HP Plot
Max RWHP: 304.2
Max RWTQ: 250
Time/HP Plot
Max RWHP: 305.4
Max RWTQ: 251
Considering what I have done to the vehicle modification wise, I'd say these numbers are spot on, and I was definitely happy to see the results. Taking into account a 13% loss of power due to the drivetrain, this would put my max BHP at approximately 350 HP.
Not too shabby for a 10-year old NA motor.
I've attached the RPM/HP plot for reference.
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides
DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake
MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS
      03-18-2016, 03:47 AM   #2
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
can't wait
Powered by
      03-18-2016, 01:43 PM   #3
No_Dominion
117
Originally Posted by Vanne View Post
can't wait
Post updated with results!
      03-18-2016, 03:33 PM   #4
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
Commented on Facebook, but I'm curious here if you're outcome is reflected by other members here. I don't know what the new engine will produce, but I wonder if euro headers and an intake will yield similar results. Also what other members have found with like mods.
I know it's out there in tons of build threads, I just wonder if this is about where most sit with similar mods (intake, headers, tune).
◙ Shane
      03-18-2016, 03:59 PM   #5
No_Dominion
117
Considering the S54 engine is pretty high strung and almost maxed out from the factory, I imagine my results are pretty much par for the course. The only way to see significantly more gains beyond what I've done while still staying NA would require some serious engine work, and some serious time and money.
If I had unlimited funds, my dream build would involve a more aggressive cam profile with new lifters/followers to match, larger Dinan throttle bodies, under drive pulleys, Evolve carbon airbox, and a custom Alpha-N tune to tie it all together, as well as 4.10 gears to get the power down more efficiently. Even with all of that, I'd still be surprised if the engine created more than 380 BHP or so, and with all that engine work, the chances of a critical failure would be greatly increased.
I love our engines, but they definitely aren't the cheapest or easiest to make more powerful, haha.
      03-23-2016, 06:34 PM   #6
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
I can comment on Evolve's tune and how good it is. Imran and his team were able to squeeze out just under 300 at the wheels for me (299.5) with CSL headers and SS x-pipe and powerloops. Imran says it should be a bit higher since the tires I had on cause a bit of unreliable readings (Direzza Z II's), he said it's probably around 5-10% more.
You can really feel the difference mainly from 3.5-4K and up as it just pulls all the way through.
Also No Dominion, Evolve's Alpha-N software got the kinks worked out with the heel-toe and other issues they were having with our cars and the CSL box.
      03-23-2016, 06:41 PM   #7
No_Dominion
117
I couldn't agree more; the Evolve tune really tied the headers and intake together and got the most out of them. The HP line is insanely linear, maxes out nice and early at 7K, and the TQ was dramatically improved, as well.
On top of the pure power improvements from the tune, I also love the improved throttle response. With sport mode off it is much more responsive, and with sport mode on, it is smoother and far easier to use.
Definitely worth every penny.
Now I just have to see if I can squeeze out a little more power by changing to section 1 with high flow cats and perhaps an underdrive pulley set.
