      03-22-2016, 05:35 PM   #23
Steeler
Steeler's Avatar
2429
Originally Posted by 3GFX View Post
Ran catless on my Jetta. Didn't mind the smell to much for the sound and performance gain. But that was a turbo car so it'll be a different case. I'll run catless and go from there
What is your plan for emissions should the defoulers not work?
      03-22-2016, 07:10 PM   #24
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Hope and pray
I'll look at putting in some cats down the pipe and extend the O2's that or some extenders for the post cat.
      03-22-2016, 08:34 PM   #25
minmat11
Drives: 2004 BMW Z4 SC
I found an awesome deal for ceramic coating inside and outside for under $200!
      03-25-2016, 08:34 PM   #26
minmat11
My headers came in!!!
      04-01-2016, 04:37 PM   #27
minmat11
Got them silver ceramic coated!
      04-02-2016, 07:04 AM   #28
minmat11
Stock headers go bye bye
      04-02-2016, 12:46 PM   #29
3GFX
3GFX's Avatar
Pics look good.
Video and sound?
Also...how are you doing with the emissions/CEL side of things.
      04-02-2016, 12:47 PM   #30
minmat11
Pics look good.
Video and sound?
I'm finishing the install today! I got spark plug non foulers for the SES problem. Not so sure what I'll do about emissions yet. More pics and videos coming soon!
      04-03-2016, 07:43 AM   #31
minmat11
Got home late from work yesterday so I'm still a little short of finishing up. But I did get the new headers in (100% fitment), and I added the non foulers to the bungs as well. I had to really drill them in for the o2 sensor to fit flush and so that it fits well under the cars transmission. You need to drill it deep otherwise your o2 sensor's wires are gonna burn off when it touches the transmission. Tight squeeze for both o2 sensors but fitted well at the end. I'll upload more pictures when I get home today. I had to torch up the copper bolts on the end of the headers for them come out. I ended up buying new 3/8 bolts at Home Depot because these were just completely useless -_- (30 minutes gone to waste).
If you're planning on using the stock exhaust bolts with your new headers, I suggest you heat them up prior to taking them out. Makes a huge difference.
[IMG]http://i1051.photobucket.com/albums/...86A30D9E0D.jpg[/IMG]
      04-03-2016, 01:20 PM   #32
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Did headers on 2 M54 powered cars (Z3 2.5)
Some notes:
Gaskets worked fine, but I believe I did E36 gaskets the second time through, they were a little larger in diameter, and matched up to the new headers.
Yeah, sometimes not every bolt opening will have a corresponding on one the head.
You need a tune. The O2 foulers are going to do nothing - and even if they do, you still need a tune.
      04-03-2016, 01:23 PM   #33
minmat11
Some notes:
What tune do you recommend?
      04-03-2016, 10:38 PM   #34
minmat11
Finally finished installing the headers today what can I say. First impression was the sound. Noticeably louder. Sounds like a real sports car when you rev. Little to no drone on the highway. Power wise, the difference is night and day. Low end as well as high end torque have drastically improved. Drove about 80 miles after the install and no SES light has come up. I'm assuming the non foulers are working but I'll keep everyone posted as these next few days go by. I'm honestly so happy with this project. It really wakes the car up. No more restrictions! If you're supercharged, this is a must. I'll have some sound clips up soon.
Here are some pictures
No SES light yet
      04-05-2016, 08:41 AM   #35
Taskmaster
Japan
2465
http://forum.e46fanatics.com/showthread.php?t=768715
I made that thread years ago, but my recommendation is the shark injector, otherwise any tuner (like OE tuning) can remove the light AND add more power. The Shark Injector will not remove the light.
      04-05-2016, 03:45 PM   #36
minmat11
From what I'm reading, OE Tuning and AA are the most popular tunes. What do you think? And also, could you explain how to go about the tune? How do you use it or what should I do prior to it.
      04-05-2016, 03:47 PM   #37
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
What supercharger do you have?
      04-05-2016, 03:50 PM   #38
minmat11
ESS Tuning Twin Screw stage 1
      04-06-2016, 07:49 AM   #39
minmat11
What tune are you guys running? And what are their advantages.Help please!!
      04-06-2016, 09:26 AM   #40
Taskmaster
Japan
2465
Can't go wrong with either one.
      04-06-2016, 09:27 AM   #41
minmat11
How will they exactly add more power?
      04-06-2016, 11:27 AM   #42
Steeler
Steeler's Avatar
2429
I sent you a PM a week ago with my thoughts on this.
You will be running lean with freer flowing exhaust now
Do you have an AFR gauge??
      04-06-2016, 11:30 AM   #43
minmat11
I do not have that gauge.
      04-06-2016, 11:54 AM   #44
Taskmaster
Japan
2465
It's not even the A/F ratio, it's ignition and cam timing changes as well. More power os left on the table that the stock ecu isn't calibrated to handle. And they can also shut off the CEL.
