      09-01-2013, 05:07 PM   #1013
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I tried to remove my pulley with a pulley puller but there wasn't enough clearance to make it grab. Then I tried various pry bars, but they apply pressure to the grooves, and I didn't want to break my old pulley. Guess I'll leave this part to the professionals
      09-01-2013, 05:58 PM   #1014
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
You're seriously going to pay someone to do this? Use a torch to heat it up and it will slide off.
      09-02-2013, 01:33 AM   #1015
Beedub
mine got damaged when the shop used a puller to remove to pulley, i hope you havent damaged the main seal..... good luck..... it really is a delicate item.
      09-02-2013, 11:23 AM   #1016
ZStig
279
the square key is kind of laying at an angle, giving it a lot more friction. I'll try a torch
      09-03-2013, 06:29 PM   #1017
ZStig
279
I tried to work it when the engine was hot, and still no go with arm pulling. I think the majority of the friction is coming from the key being stuck at an angle. Any suggestions?
      09-03-2013, 06:49 PM   #1018
seank
enthusiast
seank's Avatar
48
I think the shop is going to have issues since it looks bound up.
      09-03-2013, 07:22 PM   #1019
ZStig
279
I wonder if this would grab it
http://www.amazon.com/OTC-4544-Profi...productDetails
      09-03-2013, 08:13 PM   #1020
Steeler
Steeler's Avatar
2428
Possibly drill the key stock out or try an easy out.
Run the easy out in until it binds and while holding the snout of the pulley try rotating what's left of the key stock back until it's square to the key way.
It looks like that key stock is too small for the key way
It should not have rotated like that.
GL
Dave
      09-03-2013, 09:26 PM   #1021
ZStig
279
GL
Dave
not sure what you mean here
      09-03-2013, 09:27 PM   #1022
seank
enthusiast
seank's Avatar
48
The puller isn't the issue. It's jammed by the key that is sideways. If that isn't fixed, the pulley will break or bend, not the steel key.
      09-04-2013, 12:16 AM   #1023
StickMon
StickMon's Avatar
Drives: 2006 MR
Seriously doubt you could get enough torque on an easy-out to rotate that key back. It would have to drive the pulley ccw on the shaft. The key didn't rotate, the pulley slipped.
You'll have to carefully drill down the center of the key, starting small, and then with successively larger bits until the walls are so thin it collapses/shears.
And the key is too small, too soft, or both.
      09-04-2013, 08:36 AM   #1024
ZStig
279
Awaiting suggestions from Vortech..
Drilling seems like a reasonable idea. Too bad I have to take the supercharger out
      09-04-2013, 12:01 PM   #1025
ZStig
279
advice from Vortech
"Tom, one of two ways either one will work.. you can heat it up with a small propane torch, do this by going in a circular motion around the outside edge of the blower pulley.. the pulley will start to sweat when that dries up the pulley should slide off. The second way is to just use a pulley puller to get it off. What is happening there usually occurs if one the pulley bolt was loose or the key is too small for the hole."
      09-10-2013, 08:49 PM   #1026
ZStig
279
Did some regular maintenance: replaced the windshield weather strip, put instructions in the DIY subforum http://www.zpost.com/forums/showthread.php?t=887578
Replaced the 1 year old hydraulic tensioner. Very proud that I did it myself actually. There is noticeably less slack now. Will test for boost differences. I'll go post a DIY http://www.zpost.com/forums/showthre...8#post14645768
I'm attaching a pic of the bracket I made to hold the lower intercooler pipe, as per someone's request
      09-11-2013, 12:40 AM   #1027
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
You must get regular manicures.
      09-11-2013, 03:28 AM   #1028
Beedub
well done tom!!! think you have the most miles on a s/c kit.... keep going broski!!
      09-11-2013, 03:37 PM   #1029
ZStig
279
lol, no, not even once. Actually have dirt under my thumb nail right now
      09-11-2013, 03:37 PM   #1030
ZStig
279
Thanks! its probably the second most complicated repair I've done by myself, very proud of me
      09-12-2013, 08:56 PM   #1031
ZStig
279
New pulley is here!
      10-19-2013, 11:07 AM   #1032
ZStig
279
wow. My oil filter housing needs to be replaced again. the long bolt that hold the hydraulic belt tensioner, broke off a chunk where it screws in... wow..
this is on a new hydraulic belt tensioner and on a stock pulley
      10-19-2013, 01:06 PM   #1033
Beedub
WTF.... surely this cant be co-incidence?? could it be possible that their is excessive vibrations or anything else going on???? one i could call it bad luck, 2 units failing?? hmmmmm investigation needed!!
      10-19-2013, 01:10 PM   #1034
ZStig
279
I dunno man. the replacement unit I bought was a used one, I'll be buying a new one this time. The piece that keeps breaking off is so thin, I'm asking VAC motorsports if they ever re-inforced it.
