      02-15-2020, 07:06 AM   #23
JimBob0047
Drives: 2006 Z4MR
Originally Posted by MadGus View Post
UOA from Blackstone...
I wouldn't trust the Blackstone too much. It could be you have already worn through the lead and coper layers of the bearings. With this engine, that mileage and the fact that it hasn't been in your possession since new I would bite the bullet and spend the 1-2k on the rod bearings depending on if you dyi or have a shop do it.
      03-28-2020, 05:17 AM   #24
MadGus
Drives: 2006 Z4MR
2006 BMW Z4MR  [0.00]
Hood release pull has no tension
https://www.bimmerfest.com/forums/sh...d.php?t=195019
This took about 15 minutes to fix, and I didn't need to remove the wheel. Didn't zip tie the plastic case yet, but will when I can find one, so that the fix is more permanent.
      03-28-2020, 05:18 AM   #25
MadGus
Drives: 2006 Z4MR
Agree JimBob... rod bearings are on the list for this spring! May DIY it, but since my only lift is a quickjack, I'm not 100% yet. Think I would have enough room to drop the pan??
      03-28-2020, 06:34 AM   #26
JimBob0047
Drives: 2006 Z4MR
I have no idea. I had my buddies shop GT PEACE Automotive in Chantilly, VA do the work. Be sure to change the motor mounts, mount arm bolts and do the VAC upgraded oil pump sprocket gear while your in there.
      09-02-2020, 06:22 AM   #27
MadGus
Drives: 2006 Z4MR
Well, she now has 58k miles on her. Still am totally loving this car!
Work completed to date (in addition to what I shared earlier in the thread):
-replaced alternator and serpentine belts
-replaced windshield cowl
-new BMW badges all around
-20w angel eye bulb upgrade
-flushed transmission
-flushed brake fluid
-replaced cabin air filter
-replaced right side headlight ballast, bulb and rear access door and seal (water got in from the rear seal)
-Michelin PS4 tires on the rear
-alignment
-purchased (but have not installed) B6 shocks and struts to install when I replace front tires over the winter
-purchased crush washers to flush power steering fluid (will do this on next oil change)
That's about it for now... have done all of this work myself (except for the alignment of course). Never really turned a wrench before buying this car... should have learned how to do this stuff years ago (YouTube and this forum are both huge helps).
