      10-30-2022, 08:56 PM   #1
Barryb97
Drives: 2006 M coupe
Switched power for gauges
Getting ready to install gauges in the ashtray area. I went through all the prior threads I could find but I haven't seen anything about where people tapped into the wiring to get "switched" power. I thought the radio would be a good bet but it is not switched nor is the cigarette lighter outlet.
06 Z4 M coupe
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
      10-31-2022, 10:15 PM   #2
Barryb97
anyone?
      11-01-2022, 10:33 AM   #3
Steeler
Steeler's Avatar
2429
06 Z4 M coupe
I know you say that the radio power is not switched but I was sure that is what I tapped into.
Can't think of anything else in that area.
      11-01-2022, 03:02 PM   #4
Barryb97
Thanks. I will do some additional probing. The other option is to just put in a switch but I rather not if I don't have to.
      11-01-2022, 05:45 PM   #5
Clearancediver
Drives: 2004 Z4
You normally "tap" into the wiring at the fuse panel in behind the glove box (remove)…. Select a fuse that is switched. There are specifically designed fuse taps which provide a separate fuse for your circuit. Any auto supply/parts store can provide you with what you need
Sent from my smart phone...
      11-01-2022, 06:59 PM   #6
Steeler
Steeler's Avatar
2429
I do remember wanting to have the ability to dim the lighting on the gauges. Reason for tapping the radio power.
No issues in the 9 years I have had the auxiliary gauges.
      11-01-2022, 07:34 PM   #7
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
Any chance you post a pic of your gauges? I'm in the process of trying to get oil pressure, coolant temp and voltmeter into the cab but haven't figured out where to locate them yet.
2008 E86 M coupe
      11-02-2022, 07:52 AM   #8
Steeler
Steeler's Avatar
2429
I forget the name of the gauge pod, but it was discontinued a while ago.
grannyknot
Edit: 3d design was the manufacturer.
      11-02-2022, 03:13 PM   #9
Barryb97
Found it. Purple and white wire. I bought the cheap to gauge pod on eBay. It was pretty rough. A lot of sanding and some body filler. Also bought a used ash tray assembly so I could get it all ready on the bench. Still in the middle of installation.
https://www.ebay.com/itm/28491428513...3ABFBM-qO4n4dh
wdb4732.00
