10-30-2022, 08:56 PM | #1 |
Rep 231
Switched power for gauges
Getting ready to install gauges in the ashtray area. I went through all the prior threads I could find but I haven't seen anything about where people tapped into the wiring to get "switched" power. I thought the radio would be a good bet but it is not switched nor is the cigarette lighter outlet.
06 Z4 M coupe
10-31-2022, 10:15 PM | #2 |
Rep 231
anyone?
11-01-2022, 10:33 AM | #3 | |
Rep 2,704
Can't think of anything else in that area.
11-01-2022, 03:02 PM | #4 |
Rep 231
Thanks. I will do some additional probing. The other option is to just put in a switch but I rather not if I don't have to.
11-01-2022, 05:45 PM | #5 |
Rep 406
You normally "tap" into the wiring at the fuse panel in behind the glove box (remove)…. Select a fuse that is switched. There are specifically designed fuse taps which provide a separate fuse for your circuit. Any auto supply/parts store can provide you with what you need
Sent from my smart phone...
11-01-2022, 06:59 PM | #6 | |
Rep 2,704
No issues in the 9 years I have had the auxiliary gauges.
11-01-2022, 07:34 PM | #7 |
Rep 782
Any chance you post a pic of your gauges? I'm in the process of trying to get oil pressure, coolant temp and voltmeter into the cab but haven't figured out where to locate them yet.
2008 E86 M coupe
11-02-2022, 07:52 AM | #8 |
Rep 2,704
I forget the name of the gauge pod, but it was discontinued a while ago.
grannyknot Edit: 3d design was the manufacturer.
11-02-2022, 03:13 PM | #9 |
Rep 231
Found it. Purple and white wire. I bought the cheap to gauge pod on eBay. It was pretty rough. A lot of sanding and some body filler. Also bought a used ash tray assembly so I could get it all ready on the bench. Still in the middle of installation.
https://www.ebay.com/itm/28491428513...3ABFBM-qO4n4dh
wdb4732.00 |
