      03-20-2018, 10:29 PM   #1
E86Z
Drives: 3.0si
Rev motoring silicone boot n52
Hi all, I've been looking to purchase the Rev motoring boot for my n52 z4 but while cleaning my airbox I noticed the 328 n52 intake is different than ours:
Ours has a tube going to the "sound conducting medium" bottom diagram vs top
http://www.realoem.com/bmw/enUS/show...diagId=13_1173
Has anyone installed the boot? Is it okay to just leave that part opened?
Thanks
      03-21-2018, 05:59 AM   #2
wdb
dances with roads
wdb's Avatar
4732
The Rev motoring part appears to be intended to increase intake sound by removing the sound reduction stuff. N52 Z4s (3.0si at least) have a sound tube connecting to the firewall that transmits intake noise to the interior. If you want more intake sound, take that tube out and remove the foam pieces inside it. Presto.
      03-21-2018, 01:10 PM   #3
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
It adds a few hp too.
      03-21-2018, 10:37 PM   #4
E86Z
Drives: 3.0si
I'm looking for better flow. Which should be achieved by taking out the silencer. But the piece used to bring sound through the firewall would be flapping in the breeze so to speak. Is that a problem?
      03-21-2018, 11:32 PM   #5
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
I have a custom silicone coupler from the airbox to the throttle body. I have that sound generator tube just ziptied to one of the lines near it. I havent lost it or ran into any issues. Or you can even delete the tube/gasket and get the firewall plug #13747514866.
      03-23-2018, 10:54 PM   #6
E86Z
Drives: 3.0si
Thats good news. Where did you get your coupler? Did the in cabin sound change?
      04-01-2018, 02:05 PM   #7
Asianoak
Asianoak's Avatar
Drives: '11 E92 M3 & "11 X3
2011 M3  [0.00]
Thanks
I had the Rev Motorsport tube for my 328 and tried putting it on my Z when I sold the 3 series. Doesn't fit. I never really noticed a power increase with it but it did seem to help throttle response. One of those "why not" mods in my opinion.
Instagram: @dasianoak
      04-02-2018, 09:03 AM   #8
E86Z
Drives: 3.0si
That's some good info, did you sell the tube?
      04-02-2018, 06:21 PM   #9
Taskmaster
Japan
2465
Cut off the silencer for the same effect. It was worth about 2whp.
      04-06-2018, 01:53 AM   #10
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
I have a AFE intake tube modified to fit onto a cheap $ silicon tube mated up to my stock airbox. Yes the in car sound changed alot, because i deleted my intake boot/sound generator tubes. Less in car noise, but more outside engine induction noise with this setup
      09-09-2020, 05:41 PM   #11
mpathic
Drives: Z4 MCoupe,3.0Si R,E61 535xiT
What silicon boot did you use? The thread is a bit old, just got an N52 Z4 and looking for a silicon boot to use. thx.
And you may ask yourself, "Where is that large automobile?"
      09-09-2020, 06:44 PM   #12
Steeler
Steeler's Avatar
2429
These guys have everything you'd ever need in silicone. Hoses and fittings half way down the page.
No affiliation.
http://www.frozen/ put in boost after frozen. Was edited out by this website.
or try this https://www.siliconehose.com/
