      07-22-2013, 01:55 PM   #1
Chee_Dog
Drives: 07 328xi
Loud engine and ticking on M
I know that the M's are loud motor but this is really loud since I've gotten it to run. Any inputs, it could be the belts but I'm hearing it coming close to t
he exhaust headers as well.
      07-22-2013, 03:11 PM   #2
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
exhaust leak!
Daily: 2010 Tacoma Double Cab
      07-22-2013, 03:22 PM   #3
Beedub
Originally Posted by kennyfrc View Post
exhaust leak!
hmmm not sure, it sounds too metalic to be exhaust leak... could be wrong however....
      07-22-2013, 03:26 PM   #4
Chee_Dog
Drives: 07 328xi
Really loud ticking
      07-22-2013, 05:50 PM   #5
seank
enthusiast
seank's Avatar
48
I'm with Beedub here. Too metalic, but videos aren't the best for sound. Sounds like a mean s14, but its an s54. Exhaust leaks, header leaks make it sound more like an Subaru WRX
When were the valves adjusted?
      07-22-2013, 06:03 PM   #6
Chee_Dog
Drives: 07 328xi
Im the second owner so doubt valves were ever adjusted and sitting at almost 30k now
      07-22-2013, 06:24 PM   #7
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Motor Mount bolts broken perhaps?
2006 Z4MC - #LL93158
      07-22-2013, 08:06 PM   #8
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Get a mechanic's stethoscope and listen to different parts of the engine. Probably the easiest way to locate a sound.
Also, what work was done to get it running? Did it sound like that before the work was performed? Usually the last thing done to the car before the car started making this noise is a good place to start.
      07-22-2013, 08:49 PM   #9
Chee_Dog
Drives: 07 328xi
Just replaced oem parts like cai, plugs, spark plugs, coils, belts.
      07-22-2013, 09:16 PM   #10
AraquielZ4M
code_monkey06468
Drives: Z4M Coupe
Sounds like my old S52 when the VANOS was on the way out... Haven't heard an S54 w/ the VANOS tick before... so can't say for sure.
-- J.
07 Z4MCoupe
      07-23-2013, 05:28 AM   #11
GriffBrew
Drives: 2006 M Roadster
Does it increase when revved?
      07-23-2013, 12:26 PM   #12
exdos
England
Drives: Z3 M Coupe(S54) and Z4 M Coupe
Doesn't sound like deep within the engine. Water pump?
      07-23-2013, 02:06 PM   #13
Chee_Dog
Drives: 07 328xi
it sounds consistent with the engine rev, when rev it increase, when idle it is stable. I don't think it's the water pump, don't hear noise from there, it sounds like it is really coming from the header side/head and maybe by the header. I did also notie a rubber burning smell coming from behind the engine, it could be the heat shield burning though. Will get more videos.
      07-23-2013, 02:20 PM   #14
Chee_Dog
Drives: 07 328xi
      07-23-2013, 03:22 PM   #15
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I would do a valve adjustment first as the car is at 30k. Check if any codes exists. Front passenger side engine is timing chain tensioner. You can remove it to see if it is functioning properly. Seem like that is where the noise is coming from.
      07-23-2013, 04:02 PM   #16
Chee_Dog
Drives: 07 328xi
good piont, i was on youtube looking up noise from similar TCT problems and they sound similar. I might have to replace that before taking it in for a valve adjustment since it seems much more complex then what i could do. Any good site for a new TCT?
      07-23-2013, 04:52 PM   #17
seank
enthusiast
seank's Avatar
48
Have you taken it to a shop to diagnose?
      07-23-2013, 05:24 PM   #18
Chee_Dog
Drives: 07 328xi
Car is missing body panels so not yet.
      07-23-2013, 06:39 PM   #19
RobMCoupe
RobMCoupe's Avatar
60
Looks like number 5 from RealOEM.
http://www.realoem.com/bmw/showparts...05&hg=11&fg=25
I usually get my parts from getBMWparts. FCP Euro is another place I source some parts.
Valve adjustment is not that hard. All needed tools are in many DIYs out there. You can check all the valves and order the shims from dealer. You are not driving the car at this time.
      07-23-2013, 07:37 PM   #20
Chee_Dog
Drives: 07 328xi
Is head cover needed to be taken off for the tct?
      07-23-2013, 08:27 PM   #21
GriffBrew
Not a "How-To", but just to point out there there are two different tensioners - one is simple and one a little more involved. http://www.m3forum.net/m3forum/showthread.php?t=31094
Honestly, it's hard to tell from sound clips and I'm not a veteran car guy (quickly learning). When I picked up my car last year, I assumed it was due for a valve adjustment. it was quite noisy "like a diesel", as it's often said. After adjustment, it sound totally different. Hard to say now, but yours sound like it could just be that simple - enough valves that need adjusting. I'd start there before spending a bunch of money on possible items - you know it needs that. Based on price and working with a trusted mechanic, you could determine if replacing anything else while it's opened is worthwhile (like the upper TCT).
I don't think you need body panels for a valve adjustment
      07-23-2013, 08:49 PM   #22
GriffBrew
I see you're rebuilding this, so maybe you can drive it for a valve adjustment. Maybe try to reseat the spark plugs, just to be sure. I assume it wasn't this loud prior to the crash?
What was wrong with it after the crash that you had to replace the CAI/plugs/coils/belts? Perhaps that will clue in some ideas of what might cause this.
