      03-12-2012, 02:41 PM   #1
prodigal_m
Member
prodigal_m's Avatar
Drives: 2018 Estoril Blue/Black F31
Has anyone run 335 rotors (blanks) on their MZ4?
I had been looking to replace my factory front rotors and was considering picking them up from www.racingbrake.com but the back breaking cost has kept me from pulling the trigger thus far. I have heard nothing but rave reviews (from the hack) and from a few others that have been running the rotors on their cars (not MZ4's.) I figure if I could get 3 or 4 years out of them it would definitely be worth the price of admission.
http://www.racingbrake.com/Two_piece...tio_p/2102.htm
Forum member BTM pointed out to me that it's the same size as the 335i blanks (which should fit.) If they work that's a huge cost savings even over OEM rotors!
http://www.turnermotorsport.com/p-21...335d-pair.aspx
Has anybody tried this or am I going to be the first (after a bit more research of course.)
      03-12-2012, 03:20 PM   #2
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
Do you really want to go from a floating rotor setup to 1 piece ones? Sounds like a bit of a downgrade to me.
My tuppence worth...
      03-12-2012, 03:25 PM   #3
prodigal_m
Member
prodigal_m's Avatar
I share the same concerns but for $100 bucks a blank I'm thinking it may be worth it. (I figure that I can typically get a max of two years out of factory rotors on the track anyway.)
      03-12-2012, 03:29 PM   #4
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
there is no chance of an e9x 335 rotor fitting...
the hat depth dimension is completely different between the two.
///M ~ 1.000 inch
e9x ~ 1.688 inches
hat depth being the distance from the outer friction surface to the wheel mounting face.
the only way i see that working is to mount a spacer BEHIND the rotor and install a much less aggressive offset front wheel. do not do this. bad things will happen if you do.
      03-12-2012, 03:33 PM   #5
prodigal_m
Member
prodigal_m's Avatar
///M ~ 1.000 inch
e9x ~ 1.688 inches
This is what I was looking for...Thanks!
      03-12-2012, 03:56 PM   #6
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
Not sure how it is now, but Racing Brake couldn't fulfill my order a year and a half back.
see email dated 12/2010
Thanks for your inquiry. We used to produce the Z4m front two-piece rotor, but have stopped production since demand was low. We can make more of them, but only if there is enough interest. Do you think that there would be several Z4M owners who might also be interested? We might have a one of our dealers run a group buy, since these rotors can also be used on the M3 E46 Competition model, and our dealer could cross-promote on two forums.
If you are interested in the rear rotors, we are working on those, and when they are complete, they will not have any hardware interference issues and will be a direct bolt-on. ETA for those would be about 16 weeks.
Let us know if you think there would be sufficient demand for these rotors.
Mike
      03-12-2012, 07:11 PM   #7
The HACK
The HACK's Avatar
1821
That really is too bad there isn't enough interest. Potentially though, the hubs on the E46 M3 is the same as the hubs on the MZ4, so the same rotor would fit the M3. If y'all want to generate more interest, I'd start with the M3 folks first (and I've made this suggestion to RB as well).
I'm sure if you can get a set of 10 rotors (20 total) ordered they'd be happy to accommodate, regardless of whether or not it's for the MZ4.
Tags
335i, blanks, mz4, racing brake, rotors
