      08-19-2014, 12:58 AM   #1
zzzzz
Drives: Z4
Do I need wheel spacers
I'm about 1/4" from edge of rim to inner front fender
The rear is less or about 3/16"
I see videos from Eibach which they measured from edge of rim to the outside of the fender instead. This measurement would be close to 3/8" for me
      08-19-2014, 01:05 AM   #2
zzzzz
Drives: Z4
      08-19-2014, 01:14 AM   #3
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
looks fine, pretty flush imo need better pics to tell. what are the wheels specs? If you prefer a more agressive look add spacers? its all really preference if you have no clerance issues.
2007 BSM Z4M Coupe - 18" VOLK TE37 - 18" Apex ARC-8 - GC Track/Street
      08-19-2014, 11:19 PM   #4
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
+1, it's entirely subjective. Based on the photos I'd say this looks fine. Fairly flush for a standard setup, definitely don't think it looks bad! If anything, adding spacers may cause some rubbing issues if your fenders aren't rolled. Looks like you can probably get away with a 3-5mm if you really want to give it a shot.
Have any shots of your whole car?
-Matt
| Z4M Build Thread | @violetnites | flickr |
      08-20-2014, 11:37 AM   #5
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Nice! Fitment looks spot on. Like mentioned above ^ you may have room for a 3-5mm, though, may be on the border of rubbing/fender modification
      08-20-2014, 08:25 PM   #6
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
you are safe for a 5mm spacer easy with no issues. even a 10mm will be fine
instagram: @ dubsesd
      08-21-2014, 01:46 AM   #7
zzzzz
Drives: Z4
Can I run 5mm spacers for the front and no spacer for the rear?
I think the rear is well flush imo
      08-21-2014, 10:49 PM   #8
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Judging from this angle.. rear looks spot on. Front could use a bump though
      09-30-2014, 01:39 PM   #9
mikeyyyallday
Drives: 2004 Z4 3.0i
might rub if you add spacers
2011 Mercedes Benz C63 AMG
2010 Ford Mustang Convertible V6
2004 BMW Z4 3.0i Roadster
      09-30-2014, 09:36 PM   #10
zzzzz
Drives: Z4
If I run 19x9.5 et33 is that the same as et38 with 5mm spacer?
I just couldnt find et38 for the CSL replica anymore
      10-01-2014, 11:00 AM   #11
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Yes, precisely. 9.5 ET38 + 5mm spacer will EFFECTIVELY be 9.5 ET33
      10-01-2014, 07:59 PM   #12
zzzzz
Drives: Z4
I need one spare
What offset do you have for the V703 CSL in Hyper Black
PM me pricing. Thanks
