05-16-2012, 09:01 AM | #1 |
Rep 12,570
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.07] |
Headlights Too Low After Suspension Install
I made sure to disconnect the sensor rod from the control arm joint and reinstall afterwards yet the headlights are aimed way too low. At night can't really see more than 10 feet ahead. I know the fix is to just get them aimed higher but is this the norm for those who've lowered their cars?
05-16-2012, 09:12 AM | #2 |
enthusiast
48
Rep 1,695
It would have more to do with rake, rather than just lowering the car. Drop the rear a little or get the headlights aligned again.
My .02 cents. |
05-16-2012, 09:20 AM | #3 |
Rep 1,224
Rake was the issue with mine when I lowered it. Just adjust the headlight aim, should take about 5 minutes.
05-16-2012, 09:21 AM | #4 |
instagram 997turbotom
286
Rep 7,377
You MIGHT have auto aiming headlights, and the rod you removed is part of the assembly and not connected properly. Do you remember if your headlights do a "down then up" move when you turn the car on with the headlights on?
05-16-2012, 09:23 AM | #5 |
Rep 12,570
I could've swore they are auto leveling, which is why I posted. Would've thought the auto leveling would've adjusted for the fact the car is lower. Either way I'll take a look at the rod again.
05-16-2012, 09:54 AM | #6 | |
Rep 1,772
Drives: 2007 Z4M Coupe
05-16-2012, 10:34 AM | #7 |
286
Rep 7,377
I have no idea
05-16-2012, 10:42 AM | #8 |
Rep 1,772
seriously. Every time I get home looks like one is looking ahead and the other one is wandering off somewhere! I want to be more like
05-16-2012, 11:09 AM | #9 |
Rep 12,570
If you mean your right side aims further ahead that is correct, so you don't blind on coming drivers
05-16-2012, 01:06 PM | #10 |
Rep 1,772
right one is higher if that makes sense
05-16-2012, 01:12 PM | #11 |
286
Rep 7,377
yeah, so you don't blind incoming traffic on your left side. normal if within stock specs
05-16-2012, 02:27 PM | #12 |
Rep 1,772
Interesting and all these years I thought my car was "special"
05-16-2012, 03:27 PM | #13 |
Rep 1,101
my car is low and they level out perfectly..unfortunately I am blided every evening on my ride home. If this keeps up i will end up like ray charles.
05-16-2012, 07:16 PM | #14 |
Rep 12,570
How low was your drop? You didn't notice the beam pattern was lower than before?
05-16-2012, 07:52 PM | #15 |
Rep 704
Drives: '08 MC
I have a similar issue - except mine is the driverside headlight seems like its always on highbeam. And this was only occuring after I got the car back from a front bumper respray at the body shop... which means they didnt align it when they re-installed the headlights.... are you guys doing a headlight alignment session nearby?
05-16-2012, 08:07 PM | #16 |
#dubspec
6344
Rep 5,201
Park against a wall and see if the steps in the cutoff are at the same level. Looking at the car from the front, and kneeling down the cutoff should show up first in the drivers side headlight. Auto leveling calibrates the projector itself, it doesn't re-align the projector. You have to manually adjust them with a hex key after lowering. Takes 5 minutes
05-17-2012, 09:30 PM | #17 | |
Rep 704
Drives: '08 MC
I have these autoleveling on my e39... and have noticed that they stopped autoleveling and that the headlights are exhibiting the same problem that Dubbed describes... hoping i can fix mine too.
05-18-2012, 11:38 AM | #18 | ||
Rep 1,101
05-18-2012, 12:28 PM | #19 |
#dubspec
6344
Rep 5,201
I'll take pics of mine tonight and describe what I mean better
05-28-2012, 07:04 PM | #20 |
Rep 12,570
So I realized the auto leveling isn't functioning and most likely because I forgot to disconnect the rears (only did the fronts). But in case anyone needs the part numbers for both front and rear they are parts 5 & 10 in the diagram
http://realoem.com/bmw/showparts.do?...37&hg=33&fg=30 Front: 37146766778 Rear: 37146752797 Last edited by 3002 tii; 05-28-2012 at 07:16 PM.. |
06-02-2012, 04:18 PM | #21 |
Rep 16
I forgot to disconnect my rear too when I changed springs and shocks. I got lucky though, auto leveling still working fine for me. Were you able to fix it? What part gets damaged?
06-02-2012, 10:48 PM | #22 |
Rep 12,570
Front rod broke, just a lapse in judgment. I remembered to disconnect/reconnect but I later had to unbolt the front suspension a week later in order to install some reinforcement plates. It was that 2nd time around I forgot to disconnect the rod. Have not fixed yet, parts were ordered but haven't arrived yet.
