03-25-2010, 06:25 PM | #45 |
Rep 304
After I got used to the car I haven't had it happen but that may be because I tend to wait a split second after letting off at 8k to pull the shifter to second. In my case it almost sounded like the selector made it past the syncro but didn't engage with the actual gear. It was a high pitch grind.
03-25-2010, 06:53 PM | #46 |
Save the Manuals
1714
Rep 2,937
have to admit, the synchros have a job... and smooth shifting has rewards.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
03-28-2010, 07:49 PM | #47 |
Rep 185
I've also noticed that. Once your at redline in first, clutch to the floor, if wait the extra half a second and then slam 2nd. It won't do it. However it needs to be said that our 50-60k$ sports cars shouldn't have this problem whatsoever. I feel this is a synchro issue. I've had syncrho issues in other cars and this problem is very similar. Going to do an amsoil tranny fluid swap. Amsoil syncrho mesh fluid.
04-05-2010, 05:05 AM | #48 | |
Rep 700
By making this minor change to your driving style, when you want to you can now shift at the redline with confidence. Thank you for sharing this secret.
04-05-2010, 12:31 PM | #49 | |
Rep 238
I think you may have the definitive answer and this is probably why some people don't have a problem and others do. |
04-10-2010, 01:25 AM | #50 |
Rep 698
In my old car(07 civic si, yea I know, no comparison) everyone was getting 1-2 shift problems at high rpms(we have same 8k rev limit). Ours was due to the mounts being too soft and it moving the motor and tranny enough to cause slack in linkages and mess up the shifts. Also on our cars if it mounts were not replaced or a engine torque dampner wasn't installed, after grind after grind happened, irreversible damage was done to the trannies and they had to be replaced for the problem to go away.
But I'm currently waiting on my M to arrive with 14k miles on the clock and I'll give some feedback soon.
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
04-10-2010, 07:28 AM | #51 |
Rep 1,090
Maybe we should do a group buy for new tranny mounts.
Rouge Engineering has them for like $55 http://www.rogueengineering.com/Merc...tegory_Code=TM
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
04-10-2010, 07:40 AM | #52 | |
Rep 503
Drives: Z4 M Coupe
04-10-2010, 07:55 AM | #53 |
Rep 1,090
Depends if its a problem with tranny movement causing the grind then the stiffer mounts could help a lot.
If its a syncro issue it might not help as much. Dont think shipping would be too much since its a relatively small package.
135i N54 manual
04-10-2010, 10:23 AM | #54 | |
Bad Lieutenant
232
Rep 3,517
04-10-2010, 10:26 AM | #55 | |
Bad Lieutenant
232
Rep 3,517
Figured I'd start with the tranny as it's inexpensive to try regardless and BMW tranny mounts aren't known to be the best.
04-18-2010, 08:12 PM | #56 |
Save the Manuals
1714
Rep 2,937
Have you guys with the grinding 2nd gear issue had the motor mount bolts addressed?
I wonder if there's a connection?
2023 G80 6MT, CCBs
04-18-2010, 10:49 PM | #57 |
Rep 698
Well, I got my car friday. So far, no grinds.
04-19-2010, 09:32 AM | #58 |
Bad Lieutenant
232
Rep 3,517
I've had mine checked repeatedly at Indie and dealership visits, I guess I have the ones made after the SIB was produced (Aug/2008), and hence the reason I'm changing the transmission mount bushings this week or early next week, probably nothing to do with the lack of smoothness (I have no grinding/crunching), but rather to do with the inconsistency with which it shifts.
04-19-2010, 12:12 PM | #59 |
Save the Manuals
1714
Rep 2,937
I took my M-R out yesterday to heat it up with revs and engine braking. The shifts were silky. as 1-2-3 were equally slick with downshifts included.
I was really looking for the symptom, but it just wasn't an issue for me.
2023 G80 6MT, CCBs
04-22-2010, 12:21 PM | #60 |
Bad Lieutenant
232
Rep 3,517
Had the Rogue transmissions mounts installed today; techs took one look and compared the ones removed and the new ones were: "nice, beefy". I find the shifting is improved and especially when braking and moving the lever, especially the 3->2 where I've been denied a couple of times. That is now gone. This isn't a cure for the notchiness, but it is shifting consistent now. The original bushings were the typical BMW hourglass rubber, you could compress the rubber with your fingers whereas the Rogue mounts are still neoprene rubber, they are far stiffer and should last much longer.
04-22-2010, 01:35 PM | #61 |
Rep 11,667
^ good to know.
Do you have an SSK installed as well?
04-22-2010, 01:53 PM | #62 |
Bad Lieutenant
232
Rep 3,517
No, the car doesn't need any type of ssk as far as I'm concerned; at least for me, the throws are nice and firm. The Whalen helps a lot with the nice firm shifts.
04-22-2010, 02:06 PM | #64 |
Rep 11,667
I agree that it doesn't need to be shorter.
I just wondered if the improved pivot bushings & mechanicals would gain similar improvements as the changing tranny bushings.
04-22-2010, 02:08 PM | #65 | |
Rep 11,667
Plus rejection of 3-2 downshifts. You will know when/if it happens. I've been lucky so far myself.
04-22-2010, 02:14 PM | #66 |
Rep 167
What I am experiencing is the grinding feel on the shifter. Only way for me to not have that is to shift slower. Is there any other tehnique that I can use to prevent this grind besides shifting slower as it is kind of defeats the purpose of driving a high performance sports car.
