      07-22-2007, 06:19 PM   #1
soeharyo
lettuce
Drives: 2003 BMW Z4 3.0i
Tires
Hello...
I am going to need some advice on changing tires for my 03 Z4 3.0i Sport
I understand that the tire sizes are 18x8 front and 18x8.5 rear
My questions:
If i am going to use the car during winter (I live in Michigan), what would be a good all-season tire?
Am I able to keep the tires just in case a few months down the road I decide to change my wheels?
TIA
Rocky
      07-22-2007, 06:46 PM   #2
GP20
Originally Posted by soeharyo View Post
Hello...
Those are your rim sizes, not tire sizes. Your stock tire set up is 225/40/18 front and 255/35/18 rear.
My questions:
TIA
Rocky
All-season tires are useless in the winter with any bit of snow/ice (and terrible during the summer) on a RWD car like the Z4. You'll be better off having summer performance tires on your stock rims, and buy separate dedicated winter/snow tires & a cheap set of 17" rims. Having a separte set of wheels also makes wheel swapping so much easier/cheaper and can be done in your own garage, and you wouldn't need to worry about the tire shop scratching your rims when they mount and unmount the tires.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      07-23-2007, 08:34 AM   #3
soeharyo
lettuce
wow that sounds like a hassle...
I guess i made the choice and now, I'll have to pay for the choice i made
      07-23-2007, 09:10 AM   #4
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
Just make sure you get a torque wrench
Best Website EVER!
      07-23-2007, 10:40 AM   #5
ZEEFOUR
Drives: 03 Z4 3.0i, 03 MB E55 AMG
If your not an aggressive driver you may not notice the difference, but they will not have the grip that the stock tires had, but if they are non ruflats you will have a much smoother ride. I don't drive my cars in the snow, but got caught in a light dusting this winter, but was able to get the Z home without drama and the traction control (yellow) light on came on a few times
      07-24-2007, 02:13 AM   #6
soeharyo
lettuce
The previous time i got caught in the snow, I was met with an accident.
sigh... how much does it cost for me to change wheel (just the service charge and not the cost of wheels and tires).
thanks
      07-24-2007, 02:59 AM   #7
GP20
Do you mean mounting the tires onto the rims? Or simply swapping a set of wheels (tires + rims)? Tire-mounting probably costs $80~$120 depending on your location. Wheel swapping/mounting costs about $30~40 in my area, but free labor if you DIY. If you've never swapped wheels yourself, don't let the idea overwhelm you. It's really easy and a 30 min (or less) job once you've done it a couple of times.
All you need are:
-Torque wrench + 17mm thin wall socket ($30 from tire-rack)
-power wrench/breaker bar ($8 from tire-rack)
-floor-jack ($25 from sears)
2016 BMW M3
2008 BMW Z4M coupe
      07-24-2007, 03:08 AM   #8
soeharyo
lettuce
The thing is that I am living in a Studio Apartment right now... so its not very convenient to have spares laying around in my apartment. Is there another solution that not driving during the snowy seasons?
      07-24-2007, 06:48 AM   #9
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
thanks
Most shops around here will do the seasonal swaps for free if you purchase the wheels and rubber from them. If not, expect to pay ~$20 per wheel if flipping rubber back and forth on your OE wheels or ~ $10 for wheel swaps. try to find a place that will store your winter setup for you for free or a nominal charge.
As far as Winter tires go on Z4's for Southern Michigan/Ontario Winters - I highly recommend Hankook Icebear W300's - If you decide to flip rubber on your OE wheels you can run 235/40/18's all around on the staggered setup, this allows you the option to rotate. As suggested by others, 17's on a Winter Alloy wheel are the way to go - 225/45/17 is what I ran on my ZHP.
http://www.hankooktireusa.com/produc...ail.asp?pid=82
Db
2006 Z4MC - #LL93158
      07-24-2007, 03:44 PM   #10
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Db
^+1...
Some shops will also store the out of season set as well.
...otherwise throw a table cloth over them & use them for end tables
      07-24-2007, 05:23 PM   #11
GP20
I live in an apartment also and at one time I had 2 sets of wheels in my living room and literally used 1 set as my coffee table.
2016 BMW M3
2008 BMW Z4M coupe
      07-25-2007, 06:13 AM   #12
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Nothing like the smell of rubber in the morning
      07-25-2007, 02:59 PM   #13
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
Or the smell of burning rubber at night ;P
