      11-02-2007, 06:55 PM   #1
jpass12
jpass12's Avatar
Drives: Z4
2004 Z4 2.5  [6.00]
Magnaflow after six months.
This is how the Magnaflow setup sounds after 6 months. I think there isn't much of a difference compared when installed.
http://www.youtube.com/watch?v=Utnw_4icHbU
      11-02-2007, 07:03 PM   #2
nyczyang27
nyczyang27's Avatar
Drives: z4 3.0si / 328xi
I like.
      11-02-2007, 08:42 PM   #3
Feyd
Feyd's Avatar
346
Drives: a DEEZZULL
i've got the same setup in the trunk of my car (except 3" tips)..... i just can't find a shop to install it!
i can't wait... sounds good!
      11-02-2007, 08:55 PM   #4
jpass12
jpass12's Avatar
Drives: Z4
2004 Z4 2.5  [6.00]
Where did you get the 3" tips at? My car sounds like it has a bigger engine. I wish I had the sound of the V10 M5 engine.
      11-03-2007, 02:15 AM   #5
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
What magnaflow muffler fits the Z4? I know the Z4 muffler is a little more stout then other BMW mufflers in terms of length. Thanks, sounds great
      11-03-2007, 11:27 AM   #6
jpass12
jpass12's Avatar
Drives: Z4
2004 Z4 2.5  [6.00]
In reality, I replaced the resonator with a small Magnaflow muffler and installed straight pipes with tips where the the stock muffler was.
      11-10-2007, 12:34 PM   #7
Feyd
Feyd's Avatar
346
Drives: a DEEZZULL
been to a couple shops trying to get this setup installed.... been under the car with the fabricators. can't seem to figure out a way to fit the magnaflow muffler in without bashing in the heat shield around the resonator in... muffler is about 1" too wide.
also to fit it in there we would more or less have to bend the pipes coming out of the converter at 90 degrees, which isn't the best solution for free flowing exhaust.
going to have to find a smaller muffler or something.... or *gasp* spend 2 months salary on a pre-fab cat-back.
kind of frustrating...
      11-11-2007, 11:31 AM   #8
jpass12
jpass12's Avatar
Drives: Z4
2004 Z4 2.5  [6.00]
The muffler shop where I took my car didn't mention to me any of the above mentioned problems. Maybe, they had them, I don't know! I guess that competent shops encounter problems like that all the time. It shouldn't be much of a problem if they know what they are doing. It's not impossible cause I had it done on mine. Don't give up man! Go to another shop.
      11-12-2007, 09:53 AM   #9
highgrade00
Drives: 2007 BMW Z4M Coupe
hmmm cant check link at work
any pics?
      11-19-2007, 10:30 AM   #10
Incompatible
Drives: 07 AW Z4C 3.0Si
Jpass, Any chance of getting some actual photos of the install? You've got a number of us on the edge of following in your footsteps. I've got a 2007 coupe and would like to see if there might be any fit problems. Thanks
BTW, great car color.
      11-19-2007, 05:33 PM   #11
em2b96p
Drives: cbr600rr
is it loud enough to get annoying after awhile? i want to change mine but i would like something that wont get obnoxious on long trips or make me turn my Z into a ricer.
      11-19-2007, 09:22 PM   #12
jpass12
jpass12's Avatar
Drives: Z4
2004 Z4 2.5  [6.00]
It is definitely louder! I don't think it is obnoxious. Remember that I didn't use resonator tips. I think that the resonator tips can actually mellow it out. I will try to take a few pics of my setup.
      01-10-2008, 02:42 PM   #13
Incompatible
Hey jpass, did you ever get a chance to shoot some pics of your install?
      01-10-2008, 08:10 PM   #14
Z20
Z20's Avatar
Greece
Drives: Z4 2.5 2005
