04-08-2011, 08:44 AM | #1 |
Rep 50
Dead Battery in 2006 Z4 M Roadster...need help
my car battery is dead in my 2006 Z4 M Roadster. I have tried and tried to get to the battery but I am unable to do so without breaking parts in the trunk. I am at this point, beyond frustrated. Can anyone tell me hoe to get to the car battery? I know where it is but I cannot snap open the compartment to get to it. I have never, NEVER seen a car battery this hard to get to. Any advice would be appreciated.
Also, BMW is asking for $175 for a new battery for the M Roadster. Anyone have suggestions of a good after market battery that is less expensive and works the same? |
04-08-2011, 08:49 AM | #2 |
Rep 1,546
have you tried charging it? the charge posts are under the hood if you didn't know...
04-08-2011, 08:52 AM | #3 |
Rep 50
I charged it twice. The battery is completely dead. It was my fault. I didn't put a battery tender on and the car has been stored for 5 months. I charged it a month ago and it charged then it sat for another month while I was in Florida, got home and it is dead again and nothing will get it started so the battery must be completely done in it.
04-08-2011, 09:52 AM | #4 | |
Rep 1,546
so are you having problems getting them compartment open or the battery out?
04-08-2011, 10:13 AM | #5 |
Rep 50
I can't get the compartment open. I have taken out the mat in the trunk and the tools on top of where the battery I believe is located. I cannot get the top cover off for the life of me. I've already started to tear the fabric so I don't want to continue doing that.
04-08-2011, 10:46 AM | #6 | |
Rep 527
04-08-2011, 10:51 AM | #7 |
Rep 8,033
As mentioned above, you just need to remove the plastic fasteners, and the cover will come off without an effort. If you are using force, pulling or tearing the fabric, you are doing something wrong. You know where the battery is, right? Maybe you are looking at the wrong spot?
04-08-2011, 10:53 AM | #8 | |
Rep 11,667
You have an M right? The battery is that lump in the back right corner, under the shelf where the vert top folds down. Take off the canister & all the extra bits on top of the battery. Then feel on top of the plastic for a couple of nuts that need to be unbolted.
04-08-2011, 11:06 AM | #9 |
Rep 725
^+1
it takes all of 10 seconds to get to the battery. Removal of the battery takes another couple of minutes after removing the canister/tools cover. Remove rear anchor stud bolt, then loosen the post bolts, another bolt on positive cable and it slides to the back and out |
04-08-2011, 12:12 PM | #10 |
Rep 1,989
You have a couple of options other than OEM:
1)Just replaced the battery on my 2006 Z4M roadster with an Interstate MTP-48/H6. Direct fit, no worries, and I got it for $125.00 which I beleive is a discounted price from about $165 suggested retail. Has 770 CCA vs the 760 on the OEM battery. 2)http://www.oreillyauto.com/site/c/se...=Z4&vi=1433288 Option #2 is an exact match to the OEM unit with another name on it. |
04-08-2011, 01:09 PM | #11 | |
Guilty as Charged
Rep 56
Right - three nuts. Then remove the anchor - long rod with shoe at the bottom of the battery. Pos and Neg terminal connections, disconnect vent tube at top back of battery, then the battery slides forward. |
04-08-2011, 02:50 PM | #12 |
Rep 50
thanks for all the comments. I'm going to go out to the garage right now and take a look. It is an M for those curious. I just couldn't imagine it would be this difficult. I will look for the screws to undo.
04-08-2011, 03:01 PM | #13 |
Rep 50
just checked...on the plastic piece there is nothing to unscrew. I felt along the top of the plastic piece and there is nothing that come undone. Can someone tell me exactly where these screws/nuts are? There is nothing that a philips head or ANY screw driver will fit into for that matter on this thing or any other tool. It cannot be this difficult.
04-08-2011, 03:02 PM | #14 | |
Rep 50
Little things like this are why I now have a 2011 Volvo S60 instead of the 335i or 535i as my primary driver. This is just annoying as all hell. Last edited by SilentNight; 04-08-2011 at 03:12 PM.. |
04-08-2011, 03:20 PM | #15 |
Rep 1,855
^yes, those plastic things should pop right off. Twist the flat head screwdriver underneath them if they're giving you trouble. Even if they break, they're like a few dollars for 10 at Lowes/Home Depot.
04-08-2011, 03:44 PM | #16 | |
Guilty as Charged
Rep 56
After you remove the air pump and fix a flat cannister from the top of the battery cover feel around in the recesses where they came out of for 3 nuts - I think they are 10 or 11 mm. If the top is up you should be able to raise the plastic tray to give you more room above the battery. |
04-08-2011, 03:55 PM | #17 |
Rep 316
Little things like this are why I now have a 2011 Volvo S60 instead of the 335i or 535i as my primary driver. This is just annoying as all hell.[/QUOTE]
?? This is an EASY job. First, make sure the Soft Top storage compartment is in the "up" position. There are three nuts on TOP of the Battery housing. I believe they're 10mm. They're hard to see, and recessed a little. Feel around, you will find them. Then there are only a couple little plastic pop rivets on the side, in the carpeted part. Just use a screwdriver to gently barely get center pin started out, then switch to a small needle nose pliers. They'll pop right out. Even if you DO snap one, they're like 12 cents apiece. If it wasn't a 6-7 hour drive, I'd come out and change your battery for you in about 30 seconds. If you think THIS simple job is "annoying as all hell", then you're going to find some other simple maintenance a serious P-I-T-A!! Enjoy your Volvo. When the battery goes up on THAT, be sure to post about how simple it is to reprogram the electronics in the car to match the new battery, and about Volvo's annoying little habit the windows have of not working at all when you change it. That will be LOADS of fun! Last edited by vicj; 04-08-2011 at 04:02 PM.. |
04-08-2011, 05:08 PM | #18 |
Rep 1,989
I am certainly of the opinion people should know their limitations. It sounds to me like SilentNight needs to find a good indie BMW shop and let them his servicing/repairs. It isn't worth the aggravation I am reading in his posts.
04-08-2011, 05:12 PM | #19 |
Rep 326
both the M coupe and M roadster have the battery in the front right of the trunk? didn't know this...
the stable:
2003 BMW Z4 3.0i 2020 Mitsubishi Outlander SE 2021 Jeep Gladiator Rubicon |
04-08-2011, 06:50 PM | #20 | |
Rep 50
you are correct sir. I will try again and pop those plastic caps off. Thanks again for all the advice. I am sure I look like a 100% idiot but I've never changed a battery in a car myself as I have never had a battery go bad in a car before. Beings the battery is 100% dead, I can't jump it and drive it to the nearest BMW shop (which is 50 minutes away) so I must do this myself. |
04-08-2011, 07:13 PM | #21 |
Rep 2,431
so did you find the the 3 10mm nuts located where the tools go? first one is right behind the canister holder(tool bag) and the other two are located where the pump is.
if you still cant get it give me your email and I will take a pic for you as mine is currently off
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
04-08-2011, 07:39 PM | #22 | |
Rep 50
I literally have the entire trunk torn out to get to this battery. |
