01-22-2010, 11:29 PM | #23 |
Engineer
216
Rep 2,122
Drives: M235I 2015, 335i 2011
Well I really just wanted to save the headers because I have 2 sets of them seating at home, but after I gave some time to the idea I realize is not going to be any good doing that, so I contact the guys that custom made my other headers for the v10 and I decide to custom them and make it with a better performance so that's what Im going to do. Also they will custom make a middle section cat with the bungs for me and put a 100 cspi cat for better flow. Thank's for the answer anyways and please keep us posted about any cel's hoping that this will work for you because mine will use the same concept. And if you want later on change your headers Im doing a group buy of the custom ones. Hoping to have the dyno for it in a 30 days or so.
01-23-2010, 07:45 PM | #24 |
Rep 753
02-04-2010, 08:30 PM | #27 | |
Rep 753
Here is a link to the various hardware cable options for the iPhone Rev application http://www.devtoaster.com/products/rev/index.html If you have the patience and are good with wires, the stock O2 sensor wires and EGT can be unloomed and relocated to under the car. The shop needs a pair of stock O2 sensor connectors under the engine cover to create the adapters. |
03-15-2010, 09:48 PM | #29 |
Rep 401
Here are pictures of mine, not great but give you an idea. I wish they did not tap into my supersprint x pipe but it was too late when I saw it. Regardless it works great.
http://img251.imageshack.us/i/img440...resolutio.jpg/ http://img14.imageshack.us/i/img4403...resolutio.jpg/ |
04-15-2010, 11:16 PM | #31 |
1M advocate
214
Rep 878
ok guys correct me if im wrong here... so unlike the e46 m3 the mz4 has cats in the headers and a second set of cats in the "section 1"... so to run csl/euro headers on OEM software you just install euro headers, relocate after cat 02 sensors to section 1 behind the secondary cats and the egt sensor?
So essentially the secondary cats become the primary cats?
2012 BMW S1000RR
2011 BMW M3 |
04-16-2010, 09:43 AM | #33 |
Rep 1,721
I'm getting the O-Cha sims so there'll be no need to relocate the O2s or weld bungs. I'll make a post after I install the headers on the 1st.
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center! Enter Referral ID: 420186 |
08-29-2012, 09:12 PM | #34 | |
Rep 97
http://store.vacmotorsports.com/vac-...z4m-p2637.aspx Is it realistic to expect that the stock ECU will not throw CEL with this fabspeed header? Or, I still need to relocate the 02 and ECT behind the 2nd cat? Thanks |
08-29-2012, 09:17 PM | #35 |
Rep 11,667
You will need a tune with O2 readiness or relocate them.
I have the same headers on order & plan to get the Evolve tune
10-09-2012, 02:38 AM | #36 |
OPN DIFF
475
Rep 1,908
Drives: 10' E90 M3 6MT LB
How does it sound compare to stock?
11-21-2013, 01:36 AM | #37 |
tosser
31
Rep 988
sorry for the bump -_-
i'm following that get and 02 sensors need to be relocated post secondary cat, but what if i'm running supersprint section 1 with no secondary cat? btw, i will be installing CSL headers. is there any relocating tricks i should be doing or just deal with the check engine light until I can get it tuned out.. Gracias
'07 MCoupe lots of mods |
11-25-2013, 08:11 AM | #39 | |
Rep 753
If you run cat less, there is no cleaning effect and readings on post cats will be out of range. People try things like extended bungs and simulators with mixed results. Hope this helps. |
01-28-2014, 12:50 PM | #40 |
Rep 83
Thanks for all the detailed write ups and notes... This is very useful information. I have a set of Euro headers sitting in my garage for some time now and I plan to do the install soon. After all my research, it seems to come down to two options to avoid any error messages:
1) Fabricate the stock US spec section 1 with the addition of bungs for CO2 sensors and EGT sensor (total of 3 sensors) for downstream. *Question: If I were to use stock wiring by unlooming/loosening the cables to reach the back, do I still need to extend the wires and create new adapters? 2) Leave the EGT sensor and the 2 post-cat CO2 sensors unplugged. And get a tune to deal with the error codes. |
02-10-2014, 06:56 PM | #41 | |
Rep 191
also i would like to see the fabricated wiring harness for running the wires and holding them in place. i cant seem to find any pictures of how bmw ran the o2 sensor wiring on csl/euro cars. |
02-10-2014, 07:34 PM | #42 |
Rep 452
You can always go with brand new euro cats. Bought mine through a U.S. parts dealer who was able to access the European OE parts network. Did this for three reasons; 1) preserving my U.S. spec cats, 2) my cats already had 60K miles and these parts do need to be replaced periodically, 3) ease of installation, avoiding the need to find someone who has the expertise to do this type of welding without any leaks.
As for the fabbed wiring harness, I found no need to do so. It is possible to use the wiring that came with U.S. spec cars. Yes, it does work, and nearly 1,000 miles later, I will report no codes, ever.
02-10-2014, 07:44 PM | #43 |
Rep 452
Make it easy for ya. Have a look at these videos.
http://www.zpost.com/forums/showthre...&highlight=EGT
02-11-2014, 03:32 PM | #44 | |
Rep 191
