      04-07-2008, 10:31 PM   #23
wyu177
Drives: 2019 m240i
This is what I did; i put a furniture slider on the OEM clutch stop and it feels perfect!
Originally Posted by dekaliber View Post
Could you, in theory, just stick the pad directly on the OEM clutch stop to make it taller?
I'm wondering what the difference in height is between the DIY stop and the OEM stop.
      04-08-2008, 10:49 AM   #24
Hawkeye
Hawkeye's Avatar
No_Country
2070
I can take a picture of the height difference... the OEM was about 2-3 pads shorter than the one I bought.
It was only ~$1 and needed no modification so if you are going to buy the sliders might as well get the stop as well IMO.
      04-09-2008, 09:55 AM   #25
dekaliber
I guess i was concerned about the cross-threading issue since I imagine that the clutch stop would have a metric thread (i saw a post indicating it was M10? I'll check on realoem) vs. the 3/18-16 thread on the elevator bolt.
Thanks Hawkeye -- knowing the height difference between the OE and DIY clutch stop would actually be very helpful.
Based on the reports of not being able to get the clutch in far enough to start the car in hot weather, I'm considering just making a *slightly* shorter clutch stop that will eliminate most of the travel, but will still go in far enough consistently to start reliably every time.
