11-22-2009, 08:37 PM | #1 |
Rep 4,057
Which Wind Deflector?
I’m considering getting a wind deflector for my 2006 Z4. I’m considering the clear acrylic one or the mesh one. They are both shown at the following link:
http://www.roadstersolutions.com/page69.html The clear acrylic one is cheaper and I like the look better. The mesh one is more than $100 more and I think I’ve seen comments that it is hard to install. I recall that the parts guy at a BMW dealer I talked to told me that he was surprised at how much trouble the mesh unit was to install. Can anyone comment on which is best? Is the clear one easy to install, and remove when you don’t want to use it? How about the mesh one? And are the things effective, regardless of which one I get? Cheers and thanks! Huzz |
11-22-2009, 10:35 PM | #2 |
Rep 7
I have the BMW OEM mesh deflector that I use when my wife is in the car. I don't care much for it. It doesn't seem to do much good and blocks my vision. I would buy a clear acrylic one if I were buying another one.
11-23-2009, 05:10 AM | #3 |
Rep 821
The instructions for installing the clear one are pretty straight forward and simple and comes with all the parts you need. The instructions for installing the factory mesh unit are rather complex, plus the cost of the kit. There is also a slip over factory mesh unit, that a drunk could probably install in a few minutes.
I've had two of the factory mesh windblockers on my cars and have loved them. I like the capability to install and remove easily and the factory units do that after the initial setup. I don't know how well it works on a Z. |
11-23-2009, 10:21 AM | #4 |
Rep 46
I bought a used factory net screen off of e-bay for $150. had to order the brackets from BMW for about $25. I had no instructions, but it's common sense. I measured, marked the spot and drilled 4 small holes. The brackets mounted perfectly and the screen locks in and out in 2 seconds! Visability is effected a little, but it does block some wind and looks and fits as a factory one should. A new cost about $400 and i'm sure BMW would charge you over $100 to install it. Not worth it in my eyes. I would go with a cheaper one maybe even an aftermarket e-bay version and only use it on trips. They little bit of difference it makes is not worth the money or trouble!
2006 Z4 M Roadster
11-23-2009, 08:55 PM | #5 |
Rep 602
Greetings from Beijing--am here for some time and saw the post. My Z4 stateside has the roadster solutions one and we love it. It took all of maybe 20 minutes to install, only because I measured three times for centering and made sure the wipes to remove dirt etc were used properly before adhering the three guides. I did not use the ones behind the seats...just the middle unit. I liked the polish cleaner he sends..works wonders and no scratches, does not interefer with top up and down. I did use some soapy wax on edges of plastic unit so as you slip into guides easier. Only issue is: if you take it out you need a storage bag or risk scratching...but now ours in in all the time. Clear view at night which mesh is not as good--we had one on the Z3...not as nice. Just one take on it...good luck...but its worth it.
11-24-2009, 12:00 PM | #6 |
Rep 9
I have a geniune mesh deflector
I can get you a geniune BMW mesh wind deflector for $200. I'm not sure what the other poster was referring to about brackets, but the BMW wind deflector is mesh and leather. There are leather covers with mesh inside which go over the rollbars and mesh in the mid-section. They are fastened with three straps per roll-bar. Each strap has a metal piece on the end which catches under the trim. The straps then adjust tightly. It comes with a small bag to carry it in when not in use. Takes about 10-15 to install the first time. Let me know. You can email me at dillrob@gmail.com. Bob
11-24-2009, 01:06 PM | #7 | |
Rep 46
2006 Z4 M Roadster
11-24-2009, 02:56 PM | #8 |
Rep 9
windscreen
I still don't know of the windscreen you are referring to. The "cheaper" one that I bought and installed sells for $240 on eBay and $299 on Amazon and it is a BMW part. It does attach by sliding over the rollbars and then securely clamping to the body. I am aware of the aftermarket plexiglass versions as well which I think look cool but they weren't for me due to glare concerns. Can you post a photo of the one you are referring to or provide the BMW part number since I can't find other types on the internet.
11-25-2009, 09:31 PM | #12 |
Rep 46
The one i have does not go over the roll bars. It slides between them on rails and locks in with self locking clips. it only takes two seconds to lock it in! I will post picks whaen i get a chance.
2006 Z4 M Roadster
11-26-2009, 01:59 AM | #13 |
Rep 615
Drives: 2017 G30 540i M Sport
Garage List 2002 BMW Z3 Roadster [0.00]
2007 BMW 335i Coupe [0.00] 2012 BMW 335i Sedan [0.00] 2006 BMW M Roadster [0.00] 2017 BMW 540i [0.00] 2015 BMW 428 Gran C ... [0.00] |
Follow this link to see a photo of my RoadsterSolutions clear acrylic - best windscreen IMO, nicer looking than mesh and no blind spots
http://www.zpost.com/forums/showpost...4&postcount=11 Most difficult part of install is the roll hoop pieces, but I eventually removed them - brought back a little more air, and not really needed IMO.
Mine G30 540i M Sport Hers F36 440i Gran Coupe |
11-26-2009, 07:02 AM | #14 |
Rep 4,057
But aren't the three guides for the acrylic panel permanently attached to the roll hoops and the top of the SOS panel?
Huz-Z
11-26-2009, 02:42 PM | #15 | |
Rep 1,991
For dillrob, here is the other OEM windscreen: http://forums.bimmerforums.com/forum...ght=windscreen As you can see, it has a much more professional "factory" look. It also has brackets to hold the removable center section in the trunk for times you don't want it. |
11-26-2009, 09:23 PM | #16 | |
Rep 615
11-26-2009, 09:58 PM | #17 |
Free Thinker
16919
Rep 7,455
I've had the acrylic version in since I brought the car home in March. Since then I haven't needed to clean the inside of the rear window. I don't think that should be a worry at all. Unless you smoke in the car with the top up, the rear window should rarely need cleaning. If it does, just stop the top while it's halfway up and clean it then.
11-27-2009, 06:56 AM | #18 |
Rep 4,057
The RS one is not bad IMHO and can probably be cleaned if need by by stopping the roof halw way as you say.
The very fancy OEM BMW one is ideal but I expect it will cost me about $500 and is a bit of work to install. The mesh OEM BMW one though, is little work to install and can be whipped off in no time at all. I think I can get one for a decent price too. Any other sage words of advice from folks? And thanks for all the info!
Huz-Z
11-27-2009, 09:28 AM | #20 | |
Rep 1,991
11-27-2009, 11:10 AM | #21 | |
Free Thinker
16919
Rep 7,455
11-27-2009, 04:25 PM | #22 |
Rep 615
Yes, one more thought - I used to drive a Z3, and had the OEM mesh windscreen designed for that car. Two problems with the (Z3) mesh compared to the (Z4) acrylic, 1) general visibility and blind spot across the top, and 2) cleaning - the mesh traps dust and dirt, whereas the acrylic can simply be dusted in place (or occasionally cleaned with Plexus in place).
